Re: tiei down car
[Re: dragon]
#3084875
10/10/22 03:00 PM
10/10/22 03:00 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
I always put mine in park because I know someone who had one in neutral and a tiedown came loose and it caused damage to the car.
I don't see what damage can be done, if its tied down right it won' be an issue. If its not tied down right you will be glad it was in park.
The procedure my dad and I use with an enclosed is to winch the car in, strap it down, then lastly put it in park.
68 Barracuda Formula S 340
Re: tiei down car
[Re: Bad340fish]
#3084877
10/10/22 03:09 PM
10/10/22 03:09 PM
Posts: 10,041 MN
JERICOGTX
MN
Do what you feel comfortable with. With a stick car, mine is always in neutral. 4 heavy straps, and I keep tension on the winch cable as well. We check straps every single time we get off the road for something.
69 GTX
68 Road Runner
Re: tiei down car
[Re: JERICOGTX]
#3084882
10/10/22 03:31 PM
10/10/22 03:31 PM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
I'm about to send a car 50 miles away for metal work - no motor, transmission, or e-brake. I waver between worrying and thinking if something goes wrong putting the car in park or in gear isn't likely to help anything. It's either strapped down right or it's not.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
Re: tiei down car
[Re: Bob Stinson]
#3084928
10/10/22 06:15 PM
10/10/22 06:15 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I'm about to send a car 50 miles away for metal work - no motor, transmission, or e-brake. I waver between worrying and thinking if something goes wrong putting the car in park or in gear isn't likely to help anything. It's either strapped down right or it's not. In case of an accident you're probably right, but I've seen lots of clowns through the years just tow the car in park (no straps) So park must be doing something!
Re: tiei down car
[Re: dizuster]
#3084936
10/10/22 06:58 PM
10/10/22 06:58 PM
Posts: 20,843 A collage of whims
topside
A collage of whims
I've never had a problem with an AT car in Park - stick cars I usually use E-brake - towing literally across the Country. Worked for a guy who would use E-brake & neutral on AT cars, never an issue either. Never less than 4 proper ratcheting tie-downs, crossed left/right at both ends - TIGHT, and checked from time to time - plus the winch cable. Nothing's moved yet (in many thousands of miles), and some of those cars were worth more than my home (as in Pebble Beach Concours). Main thing is the car doesn't move back or forth, or for that matter side to side, hence the crossed tie-downs. Whether I'm towing locally or across the US, same tie-down method, as I've had to avoid some real idiocy and/or junk road surfaces. Best tie-downs in the world are Mac's, though I've used arguably lesser ones.
Re: tiei down car
[Re: slantzilla]
#3085005
10/10/22 10:55 PM
10/10/22 10:55 PM
Posts: 16,507 On the run…
BloFish
On the run…
I put mine in park because it just makes sense.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: tiei down car
[Re: DusterKid]
#3085030
10/11/22 08:50 AM
10/11/22 08:50 AM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
I always put mine in park also. Never had an issue. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: tiei down car
[Re: an8sec70cuda]
#3085060
10/11/22 10:13 AM
10/11/22 10:13 AM
Posts: 3,089 Michigan
A727Tflite
The only risk of towing in park is if the roads cause the car to rock for and aft from suspension compressions. Undulating roads. As long as the car doesn’t go through those conditions you should be good. At Chrysler we learned that pretty quick. Railcars and some trailers were notoriously known for this condition. We eventually had to transport them in neutral with the IOD connector pulled. Result of this towing in park was broken or cracked extension housings. Back in the 90’s. Always place in park last after setting the emergency brake. While criss crossing the tie downs is best to keep the car from moving side to side on the trailer, it does offer more fore and aft movement. I wonder if some guys cracked extension housings and blamed it on some other event. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
Re: tiei down car
[Re: A727Tflite]
#3085095
10/11/22 12:16 PM
10/11/22 12:16 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) I always tow in neutral, Un crossed straps and winch loose... never an issue.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: tiei down car
[Re: W.I.N. Racing]
#3085147
10/11/22 02:51 PM
10/11/22 02:51 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
I don't cross my tie downs anymore, I do make them pull on the car's K member and rear end towards the outside edge of the trailer where the tie down hooks are to make sure the car won't slide either way while I'm going through corners and same thing on front to rear movements ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) :: up:
Re: tiei down car
[Re: BloFish]
#3085297
10/12/22 12:36 AM
10/12/22 12:36 AM
Posts: 11,639 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've always towed mine in neutral, even with an open trailer. The chassis car had glass doors with lexan windows and I would winch it in and out with the door on, So I couldn't get to the shifter.
Use good tie downs and tie it down right. I'm not sure being in park would do a whole lot to keep it in one spot if it did get loose.
Re: tiei down car
[Re: CMcAllister]
#3085341
10/12/22 09:49 AM
10/12/22 09:49 AM
Posts: 4,689 On the parachute mount
n20mstr
i have seen one car get jammed in park after a tow , when i had steel doors and roll up windows i would put in park after i pulled the straps tight. Now i have glass doors and lexan windows. So yea i winch it in, tie it down and its still in neutral. However i have been chocking the wheels in case it does get loose. But as mentioned before, i have added opening the trailer door and peek inside to my fuel stop routine. Cant check things too many times!
....BAD A$$ STREET CAR.....
Re: tiei down car
[Re: n20mstr]
#3085363
10/12/22 10:40 AM
10/12/22 10:40 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I winch mine in. Leave in neutral. Leave winch cable on front tow hook. Add rear straps and tighten winch until rear straps are tight. Never have to loosen ot adjust rear straps this way (for my car anyway). Add front straps and tighten them. Put in park.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
