Minimum clearance between tire and leaf spring #308469
05/05/09 10:03 AM
05/05/09 10:03 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
What is the minimum clearance to have between leaf spring and the tire?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Minimum clearance between tire and leaf spring [Re: Von] #308470
05/05/09 10:45 AM
05/05/09 10:45 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
1/4"
Re: Minimum clearance between tire and leaf spring [Re: Von] #308471
05/05/09 10:46 AM
05/05/09 10:46 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
I only have about 1/8" and tire will rub when going around corners at that.
Post deleted by moparts [Re: Von] #308472
05/05/09 10:47 AM
05/05/09 10:47 AM
Re: Minimum clearance between tire and leaf spring #308473
05/05/09 10:52 AM
05/05/09 10:52 AM
Cincinnati, Ohio
Cincinnati, Ohio
I would say 1/2" for street tire and maybe 3/4" or a hair more for a slick. The only reason I say that is the slick is a softer sidewall and will deflect and rub when making turns either when loading/unloading, during the turnaround at the end of the track etc. I have BFG radials for street tires with 1/2 clearance to the spring and never leave a scuff, But my slicks which are ET Drags you can faintly see a few scuffs on the inside sidewall. They are dimentionally the exact same size tire but one rubs and the other doesn't.
IMO you don't need more clearance with a slick verses a street tire. I've run plenty of slicks less than 1/4" from round tubing and they never touch except maybe a little during tire shake.
Re: Minimum clearance between tire and leaf spring [Re: Challenger 1] #308474
05/05/09 10:56 PM
05/05/09 10:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My Hoosier QTP's had a good 1/4" and they rubbed on turns all the time as I drive it alot on the street. I got new 8" steelies with a different offset and now I have over 1/2" and they dont rub anymore. Ron
Re: Minimum clearance between tire and leaf spring [Re: 383man] #308475
05/05/09 11:59 PM
05/05/09 11:59 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I have 3/8" with my slicks and they don't rub...but they did at 1/4".
Re: Minimum clearance between tire and leaf spring [Re: Quicksilver440] #308476
05/06/09 12:22 AM
05/06/09 12:22 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
id try to shoot for 1/2" just my
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Minimum clearance between tire and leaf spring [Re: Stroker Scamp] #308477
05/06/09 02:00 AM
05/06/09 02:00 AM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
I went to M/T drag radials from QTPs and they are way better about not rubbing. I have less clearance than the QTPs and very minimal rubbing now.
Anything bias ply is going to not like going around corners with minimal clearance I think...
Re: Minimum clearance between tire and leaf spring [Re: Von] #308478
05/06/09 04:40 AM
05/06/09 04:40 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I think you need a little more clearance when you remove the clamps behind the axle that hold the leafs together. I remove mine for better leaf separation and notice that it will allow the axle to move more side to side in turns.
Just don't go so fast in the corners.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
