They make running 6's easy..... #3084528
10/09/22 12:28 PM
10/09/22 12:28 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Re: They make running 6's easy..... [Re: Dragula] #3084567
10/09/22 02:45 PM
10/09/22 02:45 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Admittedly they don't test all that much but Mullet seems to show how sensitive tuning is at that power level to getting down the track on radials. They switched from the LS to a SMX big block with bigger turbos and so far it's only gone 3 tenths quicker!
The stick car next to him is apparently running a 1st gen SBC, pretty incredible.
Re: They make running 6's easy..... [Re: Blusmbl] #3084598
10/09/22 05:01 PM
10/09/22 05:01 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Buy viper, add motec and turbo's, go 6's.
https://youtu.be/fPUBU3Wa5lk
Re: They make running 6's easy..... [Re: Uberpube] #3084613
10/09/22 06:26 PM
10/09/22 06:26 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
It's ea$$$$$$$$$$$$$y.
Re: They make running 6's easy..... [Re: CMcAllister] #3084617
10/09/22 06:44 PM
10/09/22 06:44 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Dragula u need to buy my wedge stuff.
You be right there with them
Re: They make running 6's easy..... [Re: FastmOp] #3084620
10/09/22 06:53 PM
10/09/22 06:53 PM
Dragula Offline OP
Dragula  Offline OP
Why, watcha got?
Re: They make running 6's easy..... [Re: Dragula] #3084626
10/09/22 07:11 PM
10/09/22 07:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Indy headed stuff that runs 160 in the 1/8
Re: They make running 6's easy..... [Re: FastmOp] #3084685
10/09/22 10:57 PM
10/09/22 10:57 PM
Thats pretty stout up bow
Is that with or without a power adder?
PM me if you want with a reply, please. I'm working on a new combination for some local No Prep up here in the Norwest, shooting for low 4. at 160 + MPH with big tires in the 1/8 mile: luck:
Re: They make running 6's easy..... [Re: Cab_Burge] #3084713
10/10/22 06:50 AM
10/10/22 06:50 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Single turbo Cab.
Re: They make running 6's easy..... [Re: Cab_Burge] #3084714
10/10/22 06:51 AM
10/10/22 06:51 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have found the stuff Cleetus does pretty interesting, there is plenty of dumb involved but he shares the struggles as well as the wins when it comes to his drag racing efforts.
He had the same guy in the final of two different classes last night at FL2K. He went 6.59@219 on a 275 tire at 3550lbs. That is moving. He also got Peter Harrel of HED involved with the tuning and found damn near a half second once he figured out how to use the davis traction control.
68 Barracuda Formula S 340
Re: They make running 6's easy..... [Re: FastmOp] #3084727
10/10/22 07:48 AM
10/10/22 07:48 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Single turbo Cab.
What block of choice you use?
Re: They make running 6's easy..... [Re: racerx] #3084730
10/10/22 08:00 AM
10/10/22 08:00 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Indy Max
I'm at the limit of the wedge stuff.
Re: They make running 6's easy..... [Re: Bad340fish] #3084747
10/10/22 09:12 AM
10/10/22 09:12 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Same here. What's even more impressive is he does the drag and drive events with the car! He's not afraid to get in, get dirty and learn what he needs to.
They are finally getting all of the fleet sorted with a little help from professionals. It will be interesting to see James get the 240SX figured out since that thing is so small and light!
'63 Dodge 330
11.19 @ 121 mph
Re: They make running 6's easy..... [Re: GY3] #3084759
10/10/22 09:41 AM
10/10/22 09:41 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That blazer with the roots blown LS on it really surprises me, and I think it did them as well. I never thought that would be an 8 second deal.
