1966 426 hemi main web welding #3083456
10/05/22 07:20 AM
10/05/22 07:20 AM
NY
moparmatt0 Offline OP
NY
I have a 66 hemi block that is stamped ramchargers by the pan rail going out to the bellhousing bolt.The main web at the second to last main bearing is cracked on both sides of the oil hole does any body know any one who repairs these blocks thanks for any help Matt 845-206-2743
Re: 1966 426 hemi main web welding [Re: moparmatt0] #3084199
10/08/22 02:01 AM
10/08/22 02:01 AM
Cab_Burge Online work
Cab_Burge  Online Work
Any heavy duty industrial cast iron repair shop should be able to fix it properly in their welding furnaces, try asking at any local H.D. equipmentmen repair shop who they use scope
Re: 1966 426 hemi main web welding [Re: Cab_Burge] #3084579
10/09/22 03:08 PM
10/09/22 03:08 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Diesel shops may be a good resource as they frequently have to repair large diesel heads that are cracked.
Re: 1966 426 hemi main web welding [Re: moparmatt0] #3088422
10/22/22 10:46 PM
10/22/22 10:46 PM
After having it welded make sure the main bearing align bores are within factory tolerances, it may need align honing scope twocents
