Page 1 of 4 1 2 3 4
Another wheel tire combo question. #3084159
10/07/22 10:18 PM
10/07/22 10:18 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
69 SUPER BEE, dana 60 factory width. 15x10x5.5 BS WITH A 295/65/15. Ive searched and read and searched and read and i cannot get a definate answer on weather or not this combo is going to fit. I know the 15x8x4.5 will but what about the 15x10x5.5. Any try it? Or anyone run it? Im dead set on the 295/65 its the rim im debating.. thanks in advance guys
Re: Another wheel tire combo question. [Re: Mally69] #3084163
10/07/22 10:30 PM
10/07/22 10:30 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Also going to be using SS Springs
Re: Another wheel tire combo question. [Re: Mally69] #3084172
10/07/22 11:25 PM
10/07/22 11:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The '69 Super Bee's have a little more rear wheel well clearance than a '69 Road Runner and I only know that 275/60 -15 tires on 10x8x4.5 will barely fit on the rear of a '69 Road Runner/GTX and that is barely. It's no problem on a '69 Super Bee but so close on a RR/GTX that I went with 255/60-15's on the RR and GTX both '68 and '69 and could just get a finger of clearance between the tire and inner fender well. You might want to go to the A12 Registry here http://a12mopar.com/yabb/YaBB.pl as there's a lot of experience with wheel/tire combo's and '69 Super Bees.
Re: Another wheel tire combo question. [Re: A12] #3084237
10/08/22 09:27 AM
10/08/22 09:27 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Funny you should ask because I just measured all this on my 69 RR yesterday. The Plymouth will be the same as the Dodge except for the out tub and quarter.
From the rear quarter inside fender lip to lip is 74-1/2"
The tire you're using has a 12"cross section
10" wheel with 5-1/2" backspace + 1" of tire makes a total backspace of 6-1/2" OR 5-1/2" on the front spacing
So 60" axle width plus 11" (for two wheels/tires) = 71"
So you'll have 1-3/4" from the tire wall to the fender lip - probably more because yours is a Dodge
But the problem will be the inside of the tub. The original tubs measure 14" from the lip.
With that wheel tire combo you'll only have 1/4" clearance AT THE MOST from the tub.
A 1/2" wheel spacer will solve your problem but I think you could use a wheel with a 4-1/2" backspace with no problems at all.
Re: Another wheel tire combo question. [Re: Stanton] #3084241
10/08/22 09:38 AM
10/08/22 09:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A12 ...
What is the wheel/tire combo on the front of your Bee ??
Re: Another wheel tire combo question. [Re: Stanton] #3084245
10/08/22 09:52 AM
10/08/22 09:52 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I will say this, on my 68 Charger I have 15x10 ,4 7/8 BS, if it was 5.5 BS it would rub on the leaf spring when making sharp turns at speed because of tire flex
Re: Another wheel tire combo question. [Re: CSK] #3084254
10/08/22 10:11 AM
10/08/22 10:11 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
So a 15x10 with a 4.5 BS Will work without rubbing fender or leaf ya think? If all fails i def know the 15x8 4.5bs def works..
Re: Another wheel tire combo question. [Re: Stanton] #3084256
10/08/22 10:30 AM
10/08/22 10:30 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
So your thinkin a 15x10 /4.5bs. i would assume the 15x 10 wide rim would look better on a 295/65 than a 15x8 i think.. but im pretty sure that the 15x8x4.5 is a no brainer and it does work.
Re: Another wheel tire combo question. [Re: Mally69] #3084266
10/08/22 11:14 AM
10/08/22 11:14 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
What is your current rim/tire combo? With this, add the dimension of your new proposal, break out the tape, and see where it falls by comparison. It sounds like you are adding one inch to both the inside and outside compared to the 15x8-4.5bs
Of course, you can run a 295 on an 8" rim, you just have to run it at a lower pressure.
295 is 11.6 inches. On a 10" rim, this only allows 3/4" of sidewall bulge on each side of the rim. A 9.5" width rim would be ideal.
Re: Another wheel tire combo question. [Re: TC@HP2] #3084273
10/08/22 11:39 AM
10/08/22 11:39 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A 295 width should have a 9"-10" rim width, ideally.
I ran 295/50s on 15x8 Ramcharger wheels on a '68 RR (Hemi/4speed/Dana) and had plenty of clearance all around.
Those wheels were 4.5" BS, stock wheelhouses & springs.
Spring location is the same width - whether Belvedere/Coronet/Charger - and I'd bet the inner wheelhouse dimensions are too.
I'd mount some bare wheels & break out the tape measure and a length of straightedge, maybe a plumb bob, and verify what BS is needed.
There's been at least one member here with a '69 GTX who ran 295/65s on 15x10s with 5.5 BS without problems.
Coronets have more room at the wheel opening, of course, so 5.0 or 4.5 might center better, but a wheel opening flange is quite effective at scoring sidewalls...
Re: Another wheel tire combo question. [Re: Mally69] #3084287
10/08/22 12:06 PM
10/08/22 12:06 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
NOPE 15x10 4.5 bs will hit the outer well, all these cars were built with a very bad tolerance, most these gen B bodies with stock width Diff work with a 15x10, 5in BS
Re: Another wheel tire combo question. [Re: topside] #3084290
10/08/22 12:14 PM
10/08/22 12:14 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
I have nothing on this yet as of now. All i have to compare to is a 68 coronet allnstock suspension with stock springs and 15x8x3.75bs or a 15x10x3.75bs i need to take the tire off to verify but the tire bulges alot so its prob a 15x8 according to american racing wheels i see online. with a 29x11 hoosier slick i didnt put that on there. And the other is my 69 charger with 15x8x4.5 bs. Fits like a glove with the 275x60. But i want the 295 on this bee .. The coronet sticks to far outwards with 3.75bs.
Re: Another wheel tire combo question. [Re: CSK] #3084292
10/08/22 12:25 PM
10/08/22 12:25 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
I think ill just stick with the 15x8x4.5. Instead of playin games.
Re: Another wheel tire combo question. [Re: Mally69] #3084347
10/08/22 03:23 PM
10/08/22 03:23 PM
moparx Offline
moparx  Offline
don't forget to measure BOTH sides, no matter what you decide to go with.
the tolerances were so bad back then, that you could have up to 3/4-1" difference side to side, without the car in question being crashed in it's lifetime. 1/2-5/8" difference is very common.
that, and 50 plus years of potholes and other maladies, and who knows what a person will come up with that will effect tire/wheel fitment.
beer
Re: Another wheel tire combo question. [Re: Mally69] #3084370
10/08/22 04:57 PM
10/08/22 04:57 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
So in theory a 15x10x5bs with that tire sboukd work as well? I did find a nice wheel in a15x10x5bs
Re: Another wheel tire combo question. [Re: Stanton] #3084373
10/08/22 05:03 PM
10/08/22 05:03 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
A12 ...
Not my Bee but Gary T's. His son "Little Gary" just sent me a text (Big Gary is driving his Bee now) with his tire and wheel info:
Fronts are 15x4.5 wheels with 215/75R 15 tires.
Rear: 15x8 wheels with 4.25 back spacing, tires 29x12.5
(but I did get my Y4 A12 RM21 Road Runner in a roundabout way from GaryT who bought it from the second owner in the early '90's. Second owner bought it in 1971 from a used car lot in Youngstown, Ohio. The name of the used car lot that had the ROAD RUNNER was named..........wait for it.........................it's a ROAD RUNNER .................the used car lot was named ACME MOTORS boogie grin laugh2 no lie grin
(note the mistake of RAOAD RUNNER on the '71 title wink )
Mike
Re: Another wheel tire combo question. [Re: Mally69] #3084411
10/08/22 07:49 PM
10/08/22 07:49 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Now I am not sure if the Charger & your car have the same room, here is an old pic of mine with 15x10 4 7/8 { call it 5 } with a 295/50/15
Re: Another wheel tire combo question. [Re: CSK] #3084447
10/09/22 12:14 AM
10/09/22 12:14 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Do you have any pics of yours?
Re: Another wheel tire combo question. [Re: Mally69] #3084470
10/09/22 09:07 AM
10/09/22 09:07 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Quote
So in theory a 15x10x5bs with that tire sbould work as well? I did find a nice wheel in a15x10x5bs
I bought my wheels and tires from a guy with a Charger. 15 x 10's with 5-1/2 BS. As I previously mentioned - they would fit the OP's bee with a 1/2" spacer - which is what the guy was using on his Charger. The outer wheelhouse is not an issue on a Dodge - it is on a Plymouth.
A 15 x 10 with 5" BS will work just fine - same as if you used a spacer on the 5-1/2" BS wheel.
FWIW ALL B-bodies of that era have the same frame spacing and use the same inner tubs. It's the outers that are different and the Dodges have a bit more room than the Plymouths.
Re: Another wheel tire combo question. [Re: Stanton] #3084475
10/09/22 09:35 AM
10/09/22 09:35 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Quote
Quote
Perfect, thanks everyone. Looks like ill be going 15x10x5bs..
Page 1 of 4 1 2 3 4
