Re: Rusty 71 Road Runner Repair
[Re: CYACOP]
#3083194
10/04/22 11:19 AM
10/04/22 11:19 AM
Posts: 318 Iowa
ratroaster
Iowa
Check out this link... AMD sheetmetal Not sure what is all included with the full 1/4's. Someone else will chime in or you may have to call them.
[Re: CYACOP]
#3083203
10/04/22 11:43 AM
10/04/22 11:43 AM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
The part that's cut out is the outer rocker. You probably have rot in the bottom of the outer wheelwell and the door jamb to go along with it. Once you get past the leading edge of the quarter panel, that inside piece becomes the outside.
I bought a Duster that came with about a 2' long section of rocker, so somebody's making repair parts for it.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: Bob Stinson]
#3083234
10/04/22 01:16 PM
10/04/22 01:16 PM
Posts: 2,015 Frederick, MD
71charger
Frederick, MD
This is my '71 Charger, but the inner structure should be the same. Thought you might like to see what's underneath the skin. I edited the photo so the orientation would be correct but the website software flipped it sideways.
[Re: 71charger]
#3083244
10/04/22 01:47 PM
10/04/22 01:47 PM
Posts: 21,520 N.E. OHIO, USA
A12
N.E. OHIO, USA
Just click on the image and you can rotate the image 90 degrees clockwise at a time until it's in the correct view or orientation.
[Re: CYACOP]
#3083258
10/04/22 02:42 PM
10/04/22 02:42 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
When you see it on the outside like this, it's EVERYWHERE. What do you suppose the insides of the frame rails look like? Rusty cars from rusty climates are a structural nightmare.
