Block is cracked! #308247
05/05/09 12:04 AM
05/05/09 12:04 AM
Visalia, CA.
P
poison_ivy Offline OP
P
Visalia, CA.
Just noticed some cracks in my block the other day after taking it out of the car. It's filled with hard block above the freeze plugs and these cracks are just below that area. I think they've been there for a while. Do I have a potential problem. My machinist guy says "Run it".
Re: Block is cracked! [Re: poison_ivy] #308248
05/05/09 12:05 AM
05/05/09 12:05 AM
Visalia, CA.
P
P
Visalia, CA.
Another shot.
Re: Block is cracked! [Re: poison_ivy] #308249
05/05/09 12:07 AM
05/05/09 12:07 AM
Visalia, CA.
P
P
Visalia, CA.
One more.
Re: Block is cracked! [Re: poison_ivy] #308250
05/05/09 12:08 AM
05/05/09 12:08 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If it's just a feeze crack (appears so) and it's filled, I doubt you'll have any problems. That being said, it's just a 440 block I'd pitch it and start over if it's a fresh build, it's not like a decent 440 core is big bucks or anything.
Re: Block is cracked! [Re: poison_ivy] #308251
05/05/09 12:26 AM
05/05/09 12:26 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
If the cracks are below the grout line, they shouldn't give you too much trouble. I would clean it up, JB weld or Marine-Tek it(to prevent minor seepage), and let it fly.
MB
Re: Block is cracked! [Re: HPMike] #308252
05/05/09 12:34 AM
05/05/09 12:34 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
What were your plans for it, race or driver? A driver can be a quick fix and just put enough fix to drive it. If your gonna go for some horsepower, just dump the block and get another one.
Re: Block is cracked! [Re: migsBIG] #308253
05/05/09 08:58 AM
05/05/09 08:58 AM
Visalia, CA.
P
P
Visalia, CA.
It's a race car only. 512 stroker on alcohol. It's been 9.99 and now running mid 10's all the time. I'm pretty sure it's been cracked for some time and I just now noticed it.
Re: Block is cracked! [Re: poison_ivy] #308254
05/05/09 09:05 AM
05/05/09 09:05 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I'd run it too
If you don't have coolant in the oil it's not cracked internally, that would be my concern.
We've been running a "Non filled" 440 block 500 cu in. engine for years that has some cracks I ground and filled with JB weld not a problem. I did put a 7 lb cap on the radiator to keep the pressure down. No problem over heating.
I'd keep my eyes open for a replacement block for the next time you need some machine work done to that block and replace it then.
Re: Block is cracked! [Re: Rodney] #308255
05/06/09 12:01 AM
05/06/09 12:01 AM
Visalia, CA.
P
P
Visalia, CA.
Hey guys, I really appreciate the replies. Feels good to know I can get some straight answers. Not like some other sites where everyone likes to be a smart a#s. I'm considering the JB weld idea. Thanks again.
Re: Block is cracked! [Re: poison_ivy] #308256
05/06/09 07:49 AM
05/06/09 07:49 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Easy fix, send it over.. V it out and JB weld it.
If it is just below the hard block not much pressure on it. Do it it works, but have the surfaces roughed up and clean before applying.
logan426
Re: Block is cracked! [Re: MLR426] #308257
05/06/09 08:00 AM
05/06/09 08:00 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Never been much of a fan for JB weld. I fixed a harley shovelhead case with that epoxy stick that you kneed up to mix. I think I had the only shovelhead harley in the state that DIDNT leak oil after that..
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
