Re: Block is cracked!
[Re: poison_ivy]
#308254
05/05/09 09:05 AM
05/05/09 09:05 AM
Posts: 603 Central Oregon
Rodney
Central Oregon
I'd run it too If you don't have coolant in the oil it's not cracked internally, that would be my concern. We've been running a "Non filled" 440 block 500 cu in. engine for years that has some cracks I ground and filled with JB weld not a problem. I did put a 7 lb cap on the radiator to keep the pressure down. No problem over heating. I'd keep my eyes open for a replacement block for the next time you need some machine work done to that block and replace it then.
