Re: AFB Lobotomy
[Re: Craig J]
#3081817
09/29/22 09:04 PM
09/29/22 09:04 PM
Posts: 167 West Palm Beach, Florida
Craig J
The previous owner of my car was very optimistic in his description of the engine, so eventually I got a stockish 440 for it that has way too much piston to wall clearance, but at least it has camshaft bearings that stay in the block and doesn't leak a quart of oil every 150 miles. .
Re: AFB Lobotomy
[Re: Craig J]
#3081903
09/30/22 09:09 AM
09/30/22 09:09 AM
Posts: 12,157 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I like AFB carbs. I am not sure why, probably because so many people seem to hate the later Edelbrock versions, in particular the 1407 that have a terrible off idle lean spot after the transfer slot is fully exposed but the main circuit has not started flowing.
The CarterBrocks are not bad carbs, it's just that their tunes are antiquated and they are much more work to dial in than their competitors. Just like you are finding out. Can anyone answer why they have never done any updates to their circuits when their problems are so well known?
Master, again and still
Re: AFB Lobotomy
[Re: DaveRS23]
#3082039
09/30/22 05:52 PM
09/30/22 05:52 PM
Posts: 117 Aus
hysteric
Aus
The CarterBrocks are not bad carbs, it's just that their tunes are antiquated and they are much more work to dial in than their competitors. Just like you are finding out. Can anyone answer why they have never done any updates to their circuits when their problems are so well known? The issue with the late Federal Mogul and Edelbrock 750 carbs is they use the wrong length booster in the primary. If you look at an earlier "correct" Carter 750 you will notice the booster is longer and that places the booster where it actually needs to be which is just after the minimum restriction of the venturii. I have swapped boosters and logged where they begin to flow after the transfer slot slows stops and from memory its was around 500 rpm so thats where the dreaded lean issue comes from. You can raise the float level a little to get the primary booster to flow sooner. If it were me I would make them have 4 transfer slots 2 pump shot wells and convert them to solid fuel metering. win win win.
Re: AFB Lobotomy
[Re: DoubleD]
#3082041
09/30/22 05:52 PM
09/30/22 05:52 PM
Posts: 117 Aus
hysteric
Aus
changing to adjustable air bleeds is not complicated on an AFB Yep that's how its done.
Re: AFB Lobotomy
[Re: dragon slayer]
#3082109
09/30/22 11:14 PM
09/30/22 11:14 PM
Craig J
Those holes will disturb the airflow into the primary introducing a side shear effecting distribution, no???? It would have been interesting to see an AF ratio before and after mod. Including cylinder to cylinder on a dyno. Carter and the OEM had a lot of different strategies with the AFB. For some of the Chevy versions the anti perc tube was hidden and not exposed above the top. I am not sure.... the holes are big, but are also significantly offset from the main airflow. I suppose the hole could be covered but that was never my intention.
Re: AFB Lobotomy
[Re: Craig J]
#3082123
10/01/22 07:23 AM
10/01/22 07:23 AM
Posts: 3,916 usa
lewtot184
usa
Those holes will disturb the airflow into the primary introducing a side shear effecting distribution, no???? It would have been interesting to see an AF ratio before and after mod. Including cylinder to cylinder on a dyno. Carter and the OEM had a lot of different strategies with the AFB. For some of the Chevy versions the anti perc tube was hidden and not exposed above the top. I am not sure.... the holes are big, but are also significantly offset from the main airflow. I suppose the hole could be covered but that was never my intention. i think the real issues with the added holes is the chance of dirt getting in the air bleed. the added holes really are of no value. plugged/dirty air bleeds make the engine run poorly. the primary booster actually has two air bleeds that influence low rpm operation. there should be a small brass air bleed on the side of the booster that runs in conjunction with the one on top of the booster.
Re: AFB Lobotomy
[Re: Cab_Burge]
#3082311
10/01/22 05:14 PM
10/01/22 05:14 PM
Craig J
Seems to work ok. I think the choke function is not as effective but I probably won't be driving much in weather below 32F so probably not an issue.
Started with 0.55, then 0.70, now .063...
Re: AFB Lobotomy
[Re: Craig J]
#3082393
10/02/22 12:02 AM
10/02/22 12:02 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
BDS use to only make junk blowers, I wonder about them now Littlefields were a lot better 20 years ago I wanted to build a Bonniville car years back but SCTA and BNI eliminated the class I wanted to run it in before I could finish the car
Re: AFB Lobotomy
[Re: Cab_Burge]
#3082760
10/03/22 12:28 PM
10/03/22 12:28 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
My question is why ?
All that work and time on the 1407/1411 for what gains honestly - Subject has been beat to death on every Mopar site on the web
And the reasons have been stated over and over and over
So many better options
The Edelbrock AVS 2 is one hundred times better in every aspect right out of the box
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: AFB Lobotomy
[Re: dvw]
#3082773
10/03/22 12:31 PM
10/03/22 12:31 PM
bee1971
Sobieski Wi
I'd be interested to see what the air bleed changes are worth. I raced my car 8 years with a pair if 1407s. There was definitely an issue leaving off the foot brake even at 3000 rpm. Getting ready to run these carbs on my sons racecar. I've opened up the secondary well feeds. Tried heavy/light air doors. Various squirters. Raised the float levels. Run the idle fat. Never messed with the idle restrictions or bleeds. Never messed with the transfer slot location. At times we ran quick. But not near as consistent as the Holley's. Doug First time I heard you say anything negative about those 1407s
Re: AFB Lobotomy
[Re: bee1971]
#3082942
10/03/22 06:29 PM
10/03/22 06:29 PM
Craig J
This time I am using a 1406 it does not have the off idle lean spot. In the past the I made the 1407 work "ok" by making a really crude modification to the transfer slot using a jigsaw blade... but it was never really right.
