Edelbrock RPM valves? #3081643
09/29/22 11:09 AM
09/29/22 11:09 AM
Alliance, Ohio
V
Valiant_Showoff Offline OP
V
Alliance, Ohio
Looking for some help trying to find valves for small block Edelbrock RPM heads. Want a better, stronger option than the Edelbrock replacement valves since there new stuff is junk and they're months from being available. Does anyone know of another manufacturer of valves that fit the RPM aluminum heads?
Re: Edelbrock RPM valves? [Re: Valiant_Showoff] #3081651
09/29/22 11:19 AM
09/29/22 11:19 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Most people end up using +.100” SBC valves from they’re favorite supplier.
Re: Edelbrock RPM valves? [Re: fast68plymouth] #3081737
09/29/22 05:17 PM
09/29/22 05:17 PM
Alliance, Ohio
V
V
Alliance, Ohio
Ok, really dumb question. Plus 0.100" what? Length?
Re: Edelbrock RPM valves? [Re: Valiant_Showoff] #3081739
09/29/22 05:40 PM
09/29/22 05:40 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Check the pn out for specs but here is what I use for good street/light strip use the 5000 series. I use the 6000 series on my bracket car but 2.055 or 2.08 intakes.
HEAD DIA: 2.020"
STEM DIA: 11/32"
OVERALL LENGTH: 5.010"
TIP LENGTH: .256"
REFERENCES: 10o Under Cut - Dish Head - +.100"
STOP POTATO HATE!
Re: Edelbrock RPM valves? [Re: Valiant_Showoff] #3081914
09/30/22 09:31 AM
09/30/22 09:31 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yes, length is +.100"
so the valve is about 5.010" total, see above post.
Re: Edelbrock RPM valves? [Re: krautrock] #3082018
09/30/22 03:17 PM
09/30/22 03:17 PM
Alliance, Ohio
V
V
Alliance, Ohio
Thanks guys!
