carb jetting #308109
05/04/09 10:24 PM
05/04/09 10:24 PM
harmony pa
rampage08 Offline OP
harmony pa
just installed a new cam and now dont seem to be gettin enough fuel. the cam is .564 lift and 295 intake 307 exhaust duration. was told should step up jets in carb. i'm runnin a 750 double pump barry grant holly. any suggestions???????????????
Re: carb jetting [Re: rampage08] #308110
05/05/09 09:55 AM
05/05/09 09:55 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
How many CI's? I wouldn't expect to have to go up more than 4 sizes in the frt and rear. If the carb is right probably not more than 2 sizes. If the cam is alot bigger than the old one. You may need to try a 4 hole spacer under the carb to get a better signal to it. Jim
Re: carb jetting [Re: rampage08] #308111
05/05/09 10:12 AM
05/05/09 10:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
need more info, what engine? what was in there before? what is the current jetting..cool truck, where's the bed? loose it on a jump?
Coming soon!!!!
Re: carb jetting [Re: Mr.Yuck] #308112
05/05/09 10:44 AM
05/05/09 10:44 AM
harmony pa
harmony pa
is a 360 la. board to 410 c.i. got ported and polished edelbrock heads with 208 and 165 valves. carb is a barry grant holly 750 double pump. front is jeted at 76 and rear is at 83. my old cam was 248 duration and 484 lift and it ran perfect. couldnt find a decent short bed so i made the flat bed out of 3/16 aluminum diamond plat with 2x2 treated wood to keep weight down. bed only weighs 42 pounds
Re: carb jetting [Re: rampage08] #308113
05/05/09 10:49 AM
05/05/09 10:49 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Try jumping up by 2's and see what happends. That is a lightweight bed.
Re: carb jetting [Re: Mr.Yuck] #308114
05/05/09 10:53 AM
05/05/09 10:53 AM
harmony pa
harmony pa
thank you. just got off phone with summit tech and they said same thing. gonna give it a try.....will post results .......thanks alot
Re: carb jetting [Re: rampage08] #308115
05/05/09 12:51 PM
05/05/09 12:51 PM
Dahlonega, GA
TechAtBG Offline
TechAtBG  Offline
Dahlonega, GA
As stated jet up the front and the rear 2 numbers at a time and as long as the motor continues to respond you can add jet.
Re: carb jetting [Re: TechAtBG] #308116
05/11/09 09:19 PM
05/11/09 09:19 PM
harmony pa
harmony pa
man did that ever work.............. ran a 200 foot long and 3 foot deep pit yesterday in 6.35 seconds.....what a rush
Re: carb jetting [Re: rampage08] #308117
05/11/09 09:21 PM
05/11/09 09:21 PM
how many sizes up did you go
Re: carb jetting [Re: RapidRobert] #308118
05/11/09 09:22 PM
05/11/09 09:22 PM
harmony pa
harmony pa
4 sizes front and rear
Re: carb jetting [Re: rampage08] #308119
05/11/09 09:38 PM
05/11/09 09:38 PM
the only eng change was a different cam & 4 numbers up(per side)got it back perfect
Re: carb jetting [Re: rampage08] #308120
05/12/09 09:51 AM
05/12/09 09:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
glad it helpped.
Re: carb jetting [Re: RapidRobert] #308121
05/12/09 08:20 PM
05/12/09 08:20 PM
harmony pa
harmony pa
not just cam. changed heads and rockers to
