489 case with new R&P setup? #3081189
09/27/22 04:49 PM
09/27/22 04:49 PM
70beemine Offline OP
Hi everyone...I'm in florida so as long as I have power, I'll try to get back to my commentors! My dilemma is gear patch. I have a brand new setup that I put together (and it's my first time) with gears, suregrip, bearings and seals. If I can load my pics, I can show the marks on the gears for opinions. The BL is .008 and the preloads and torques are done. What does everyone think?
Re: 489 case with new R&P setup? [Re: 70beemine] #3081196
09/27/22 05:14 PM
09/27/22 05:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I think I would run the pinion in a few thou. maybe 2 or 3 tops, just to see what it looks like.
Make sure you use the right preload on the pinion every time you check it.
Re: 489 case with new R&P setup? [Re: 70beemine] #3081889
09/30/22 07:47 AM
09/30/22 07:47 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Take a look at the attached instruction sheet.
I find the pattern images on p14-15 to be very easy to interpret.
Attached PDF document
