Distributor Vacuum Advance Control #3080343
09/24/22 08:37 PM
09/24/22 08:37 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Need Part number for Distributor Vacuum Advance Control. for distributor 30-3816
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Distributor Vacuum Advance Control [Re: GTXKARL] #3080373
09/24/22 09:36 PM
09/24/22 09:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
What it fits would be helpful wink
Re: Distributor Vacuum Advance Control [Re: TJP] #3080544
09/25/22 02:51 PM
09/25/22 02:51 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
hi 1970 Plymouth GTX 440 engine
Re: Distributor Vacuum Advance Control [Re: GTXKARL] #3080648
09/25/22 09:19 PM
09/25/22 09:19 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I don't recognize the p/n
Original dual point would have tag with an IBS # as well as the Chrysler p/n which is 7 digits.
We can look up the original numbers in the FSM but maybe that's not an original distributor??
Re: Distributor Vacuum Advance Control [Re: GTXKARL] #3080659
09/25/22 09:40 PM
09/25/22 09:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
According to this site it's a single point distributor used on a multitude of applications shruggy
DIST LINKY
Re: Distributor Vacuum Advance Control [Re: TJP] #3080676
09/25/22 10:26 PM
09/25/22 10:26 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Good websearch!
Typical Cardone replacement - one size fits most.
What I mean by that is the parts will physically fit (usually) and work. However the mechanical and vacuum advances are unknown and they won't disclose. They beleive whatever the advances are will be close enough that the car will run OK.
Re: Distributor Vacuum Advance Control [Re: GTXKARL] #3080712
09/26/22 01:39 AM
09/26/22 01:39 AM
4 barrel or six pack motor?
Six pack motors use dual point cast iron distributor with vacuum advance, 4 barrel motors use aluminum distributors with single points and the weird looking vacuum advance with dual wire feeds to the advance unit, probably for smog reasons puke scope
Re: Distributor Vacuum Advance Control [Re: Cab_Burge] #3080730
09/26/22 07:31 AM
09/26/22 07:31 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I thought track pack option cars had the dual point.
Re: Distributor Vacuum Advance Control [Re: B1MAXX] #3080744
09/26/22 09:01 AM
09/26/22 09:01 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I think this is the one you are looking for.
1970 RB Vacuum Advance Can
Re: Distributor Vacuum Advance Control [Re: 6PakBee] #3080804
09/26/22 11:59 AM
09/26/22 11:59 AM
VA
dragon slayer Offline
VA
Is this a number matching thing or just getting a distributor to work? If you have the aluminum Chrysler distributor with points or electronic you just need any Big Block(CCW rotating) vacuum advance with a 9-11 stamp on the distributor. Could be lower too.
If you have the original distributor with retard function that would be different. A picture of the distributor with cap off to see the breaker plate would help get you the correct advice.
