Compression fitting to splice brake line? #3080635
09/25/22 08:48 PM
09/25/22 08:48 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Would you guys trust a compression fitting if you needed to splice any of your brake lines?
Thanks,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Compression fitting to splice brake line? [Re: 67SATisfaction] #3080643
09/25/22 09:08 PM
09/25/22 09:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks,
- Art
I have heard there are some that will take the pressure but you're not going to find them at the local hardware store. Just an FYI: hydraulic pressures in a brake system can exceed 2500 PSI. Myself, to answer your question NO tsk
beer
Re: Compression fitting to splice brake line? [Re: TJP] #3080647
09/25/22 09:18 PM
09/25/22 09:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Could you do it ? sure I've done it myself before BUT that was when I was a young newlywed with a baby to feed and I was broke. Now I wouldn't do it though twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Compression fitting to splice brake line? [Re: 67SATisfaction] #3080666
09/25/22 09:59 PM
09/25/22 09:59 PM
Guitar Jones Offline
Thanks,
- Art
Mmm, no.
Re: Compression fitting to splice brake line? [Re: Guitar Jones] #3080669
09/25/22 10:11 PM
09/25/22 10:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have done it but am much older and wiser now !!
Re: Compression fitting to splice brake line? [Re: Stanton] #3080672
09/25/22 10:20 PM
09/25/22 10:20 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Don’t.
Re: Compression fitting to splice brake line? [Re: Stanton] #3080673
09/25/22 10:21 PM
09/25/22 10:21 PM
Albany, NY
Albany, NY
Thanks guys, thumbs
I will never trust that shop owner again. A reputable guy too, in the vintage/exotic restoration business in the Northwest. Sold me a car recently, I bought it sight unseen, with plenty of emailed photos, but I was also relying heavily on his reputation.
The car failed its state inspection, and the compression fitting was one of several fails - the mechanic explained the same thing about pressure capacity. I think he said compression fittings are rated to 850psi, but brake systems are upwards of 2500. Thank you for letting me just double check whether anyone else used them as a common fix.
The other Fails were due to lack of cotter pins at all steering linkage castle nuts, and worn out tie-rod ends.
None of these issues are difficult or complicated, but that just amplifies the guy's sloppy work and poor service mindedness.
Live and learn,
- Art
Re: Compression fitting to splice brake line? [Re: 67SATisfaction] #3080674
09/25/22 10:22 PM
09/25/22 10:22 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Why go that apparently easy route, when a nice flare fitting would do fine?
Re: Compression fitting to splice brake line? [Re: PhillyRag] #3080675
09/25/22 10:25 PM
09/25/22 10:25 PM
Albany, NY
Albany, NY
Exactly - I'm good at this kind of work, it'll take me maybe an hour to fix it, then refill and bleed the system.. So why didn't he do it right the first time? What a crap work ethic - not to mention liability.
Re: Compression fitting to splice brake line? [Re: 67SATisfaction] #3080694
09/25/22 11:36 PM
09/25/22 11:36 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
If it’s a swagelok, parker, or yor-lok fitting, it’s likely fine pending proper install. Cheap hardware store brass compression fittings won’t cut it. The good ones are rated for high pressure.
https://www.mcmaster.com/yor-lok-fittings/yor-lok-fittings-for-steel-tubing-7/
Re: Compression fitting to splice brake line? [Re: 67SATisfaction] #3080710
09/26/22 01:35 AM
09/26/22 01:35 AM
Cab_Burge Online work
Cab_Burge  Online Work
Thanks,
- Art
Never, do you want to kill yourself or someone you love or don't know?
Buy the proper tools and learn how to use them the correct way or buy the best premade lines you can get twocents scope wrench up
Re: Compression fitting to splice brake line? [Re: 83hurstguy] #3080711
09/26/22 01:38 AM
09/26/22 01:38 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I will be honest. I see plenty of hilljacks, shade trees, guys too dumb to use a flaring tool and the "aww, I do it all the time, never had a problem" guys do it, even after being told not to.
The answer is no. Everytime.
Re: Compression fitting to splice brake line? [Re: 83hurstguy] #3080749
09/26/22 09:16 AM
09/26/22 09:16 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Absolutely true. I routinely worked with Parker CPI fittings for years in power plants at pressures up to 3500 psig. The problem is that most of these higher quality fittings are stainless steel rather than steel so you would have a materials compatibly issue.
Re: Compression fitting to splice brake line? [Re: 67SATisfaction] #3080756
09/26/22 09:43 AM
09/26/22 09:43 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Compression fittings should not be used on brake lines. I agree.
But here's the reality: I have seen plenty of them used on brake lines for the better part of 45 years and don't remember seeing a single failure due to the fitting itself. Rusty or scaly lines where they cannot grip properly is a different matter. But I have not personally seen a fitting connection fail that wasn't compromised in some other way.
I have however, seen many double flare connections fail. Usually due to poor workmanship. They take practice and a good tool. Often both can be lacking.
Not an endorsement for using compression fittings on brake lines, just my experience.
Master, again and still
Re: Compression fitting to splice brake line? [Re: DaveRS23] #3080769
09/26/22 10:20 AM
09/26/22 10:20 AM
5thAve Offline
5thAve  Offline
Compression fittings on brake likes are a big inspection fail. With the rest of the issues that are pretty basic things it sounds like that's a pretty shady shop to allow that quality or work to go out.
Re: Compression fitting to splice brake line? [Re: 5thAve] #3080966
09/26/22 08:35 PM
09/26/22 08:35 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
in nys compression fittings are a reason to fail inspection,they should not be used on a brake line.
Re: Compression fitting to splice brake line? [Re: 67SATisfaction] #3080989
09/26/22 09:21 PM
09/26/22 09:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks guys, thumbs
Live and learn,
- Art
FWIW, I have seen all of the above and more on 200K BJ show ponies as well as others wink
