valve cover gaskets #3080623
09/25/22 08:20 PM
09/25/22 08:20 PM
coquille oregon
1savoyracer Offline OP
coquille oregon
going to replace mine, one of them leaks at the rear of the valve cover, and i cannot stop it, what is a damn good gasket to get and use?..........i just want to get the best gasket possible
Re: valve cover gaskets [Re: 1savoyracer] #3080630
09/25/22 08:34 PM
09/25/22 08:34 PM
birdtracker Offline
birdtracker  Offline
what heads and what valve cover? Birdtracker
Re: valve cover gaskets [Re: 1savoyracer] #3080634
09/25/22 08:41 PM
09/25/22 08:41 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Moroso Perm-align valve cover gasket set for 383-400-440
Part # 93055
They do not leak. (and are re-useable)
Re: valve cover gaskets [Re: birdtracker] #3080639
09/25/22 08:58 PM
09/25/22 08:58 PM
coquille oregon
coquille oregon
Indy 440 heads....stock chromed valve covers
Re: valve cover gaskets [Re: jcastle1] #3080640
09/25/22 09:01 PM
09/25/22 09:01 PM
coquille oregon
coquille oregon
thank you
Re: valve cover gaskets [Re: 1savoyracer] #3080661
09/25/22 09:46 PM
09/25/22 09:46 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Surprise no one said super performance valve cover gasket here. Mine has developed a leak at the back as well, i manage to put a dap of silicone on it for now i'll get a new set over the winter.
Re: valve cover gaskets [Re: 1savoyracer] #3080693
09/25/22 11:36 PM
09/25/22 11:36 PM
AndyF Offline
AndyF  Offline
Get rid of the chrome valve covers and your leak will go away. Use a cast valve cover with a machined rail and you won't have any leaks. Indy makes a good valve cover or Trick Flow or others. I think the Cometic rubber valve cover gasket is the best on the market but you really shouldn't have any leaks with even a cheap gasket if you have two smooth and rigid surfaces that you are sealing.
Re: valve cover gaskets [Re: 1savoyracer] #3080713
09/26/22 01:47 AM
09/26/22 01:47 AM
SCE cork and rubber combination, works great and lasts a long time with a lot of use on adjusting the valves on my old drag race motors scope up
Re: valve cover gaskets [Re: AndyF] #3080721
09/26/22 06:03 AM
09/26/22 06:03 AM
coquille oregon
coquille oregon
thanks everyone
Re: valve cover gaskets [Re: 1savoyracer] #3080729
09/26/22 07:21 AM
09/26/22 07:21 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
We always used cork with the Chrome valve covers. They were only able to be used once and then had to be thrown away. I have since bought Mopar Performance Cast valve covers and Moroso blue rubber gasket with steel core. They have been on the car at least 10 years and the gaskets reused many many times without any issues.
