What enigne mounts for Hellcat or Redeye swaps #3080604
09/25/22 06:28 PM
09/25/22 06:28 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Looking to see what you guys are using...
Re: What enigne mounts for Hellcat or Redeye swaps [Re: Dragula] #3081871
09/30/22 02:00 AM
09/30/22 02:00 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Assuming your talking 1960/70s swaps, all I know is there are several companies selling components to do engine swaps. Even Dodge sells kits now.
Re: What enigne mounts for Hellcat or Redeye swaps [Re: Dragula] #3081969
09/30/22 12:03 PM
09/30/22 12:03 PM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
I went with TTI mounts for my Hellcat swap. When I did mine, Holley did not have theirs yet. The Holleys move the engine i believe about 2 inches forward, which would eliminate the need for a low profile coolant manifold for the supercharger in the rear.
Re: What enigne mounts for Hellcat or Redeye swaps [Re: 70gtx1] #3082125
10/01/22 07:32 AM
10/01/22 07:32 AM
BDW Offline
BDW  Offline
2" move forward, doesn't that cause other problems?
Driveshaft too short,
Transmission has to move with it, shifter linkage?
I bought the Holley mounts, but had to go with TTI mounts when I figured out the TTI shortie headers don't work with the Holley mounts. I already had a complete TTI system in the car, didn't want to have to redo the back.
Removed 340, dropping in 3G and the TTI shorties bolt right up to my existing exhaust.
Don't think my 518 would align up if moved 2" forward.
I'm about 1 month away of firing it up, biggest pain is the wiring
Re: What enigne mounts for Hellcat or Redeye swaps [Re: BDW] #3083427
10/04/22 11:44 PM
10/04/22 11:44 PM
IL
furious70 Offline
furious70  Offline
IL
Holley stuff looks to assume you're using all their stuff including trans mount, and while they list 727 they are catering to OD transmissions so all that stuff is changing anyway.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What enigne mounts for Hellcat or Redeye swaps [Re: Dragula] #3093442
11/11/22 01:26 PM
11/11/22 01:26 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
you can use Ls mounts and make something up
