Stripped Upper Ball Joint #3080352
09/24/22 08:51 PM
09/24/22 08:51 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
I bought a set of the inexpensive re-popped upper control arms (70 B-body). I swapped out the ball joints and bushings for Moog parts. Unfortunately after removing the ball joint from one of the uppers, the threads in the control arm are stripped and the new ball joint won’t take any real torque.
I have heard that welding the ball joint into place is an option. Thoughts? Other fixes?
Thanks.
Re: Stripped Upper Ball Joint [Re: BPBP440] #3080363
09/24/22 09:22 PM
09/24/22 09:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Jack up the side that won't tighten with the jack under the lower control arm. That should put pressure on the upper ball joint a keep it in place while you tighten it.
Re: Stripped Upper Ball Joint [Re: stumpy] #3080371
09/24/22 09:35 PM
09/24/22 09:35 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Stumpy, I think he is referring to the upper ball joint threads in the control arm. up
To the OP I have seen more than one tack welded beer
Re: Stripped Upper Ball Joint [Re: TJP] #3080375
09/24/22 09:40 PM
09/24/22 09:40 PM
BPBP440 Offline OP
BPBP440  Offline OP
You are correct sir. Thanks for clarifying.
Re: Stripped Upper Ball Joint [Re: TJP] #3080376
09/24/22 09:42 PM
09/24/22 09:42 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Moog used to make over sized uppers for stripped threads.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Stripped Upper Ball Joint [Re: 340SIX] #3080379
09/24/22 09:44 PM
09/24/22 09:44 PM
BPBP440 Offline OP
BPBP440  Offline OP
Originally Posted by 340SIX
Moog used toi make over sized uppers for stripped threads.
Were they “self tapping”? That sounds like a good plan.
Re: Stripped Upper Ball Joint [Re: BPBP440] #3080399
09/24/22 11:26 PM
09/24/22 11:26 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Came across welded bj's in the past.
1/2 doz tack welds across the top would hold fairly well for street driving.
All metal there, so nothing really gets damaged.
Of course the grease needs replacing.
Re: Stripped Upper Ball Joint [Re: PhillyRag] #3080417
09/25/22 12:35 AM
09/25/22 12:35 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave I Remember MOOG offered those Ball Joints in the 70s -Early 80s . But fell out of favor like Air Shocks . drive Do you still have your Good Old Original MOPAR Arms ? bump Ronnie
Re: Stripped Upper Ball Joint [Re: 1969ronnie] #3080433
09/25/22 07:08 AM
09/25/22 07:08 AM
BPBP440 Offline OP
BPBP440  Offline OP
I picked up these replacements because the upper ball joint threads were in bad shape when I removes the old ball joint from the original. Same side. Bad luck.
Re: Stripped Upper Ball Joint [Re: BPBP440] #3080476
09/25/22 10:57 AM
09/25/22 10:57 AM
BPBP440 Offline OP
BPBP440  Offline OP
UPDATE: In my searching, I see that the re-pop arms now carry a warning that says the K772 is too small and that the K772C is the correct replacement ball joint.
Re: Stripped Upper Ball Joint [Re: PhillyRag] #3080484
09/25/22 11:14 AM
09/25/22 11:14 AM
Indianapolis, In. area
BTBelvedere Offline
BTBelvedere  Offline
This was pretty common back in the day. Welded lots of them.
Re: Stripped Upper Ball Joint [Re: BPBP440] #3080507
09/25/22 12:48 PM
09/25/22 12:48 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
COOL, wonder if it takes the same size socket? as I recall there were two different sizes, a body being small, b,e,c large wink
Re: Stripped Upper Ball Joint [Re: BPBP440] #3080513
09/25/22 01:12 PM
09/25/22 01:12 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thank you for posting that. Excellent info!
…but, why would these repro guys use an oversize ball joint on there repro parts? realcrazy spank rant What ding-a-lings!
All I can figure is careless design or they couldn’t figure out how to manufacture the threads exactly so the oversize was their fix ?
Re: Stripped Upper Ball Joint [Re: BPBP440] #3080515
09/25/22 01:15 PM
09/25/22 01:15 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Interesting
Went thru this same issue about five years ago with these Chinese reproduction uppers
I just went to tighten or re torque what ever they where using for Chinese ball joints and they stripped out while I was applying torque
The company that I purchased them from just sent me out new ones without any questions asked
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Stripped Upper Ball Joint [Re: bee1971] #3080554
09/25/22 03:33 PM
09/25/22 03:33 PM
BPBP440 Offline OP
BPBP440  Offline OP
Interesting
Unfortunately I have been sitting on these for a few years now before I got around to installing.
Re: Stripped Upper Ball Joint [Re: autoxcuda] #3080560
09/25/22 03:39 PM
09/25/22 03:39 PM
BPBP440 Offline OP
BPBP440  Offline OP
I assume the same. Since one side took a K772 to full torque and the other side didn’t get past 40 ft-lbs, I imagine they have trouble holding a consistent tolerance and went to the larger Ball joint as an afterthought.
Re: Stripped Upper Ball Joint [Re: BPBP440] #3080563
09/25/22 03:51 PM
09/25/22 03:51 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Stripped Upper Ball Joint [Re: TJP] #3080571
09/25/22 04:36 PM
09/25/22 04:36 PM
340SIX Offline
340SIX  Offline
CO OL, wonder if it takes the same size socket? as I recall there were two different sizes, a body being small, b,e,c large wink
I have 3 diff size Snap-on sockets one fur A, one I used on B&E and one I just used 2 or 3 times. Can't remember if it was Sea, or truck. The manager at Western Auto was a friend frim way back before he worked there and he would call.me when an old Mopar came in.
He would tell.the young guys I know a guy. But anything I needed there was at cost and had use of the lift if needed.
Then guts working there looked at me like I was from another planet when I asked for the 3/4 Impact.
Re: Stripped Upper Ball Joint [Re: 340SIX] #3082141
10/01/22 09:31 AM
10/01/22 09:31 AM
BPBP440 Offline OP
BPBP440  Offline OP
Problem solved, bought some QA1 tubular uppers.
Will be putting these up for sale with the original ball joints (one will need to be tacked) and moog offset bushings installed.
Re: Stripped Upper Ball Joint [Re: BPBP440] #3082223
10/01/22 01:19 PM
10/01/22 01:19 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
And your alignment man will thank you wink
