Mopar transmission ID #3079458
09/21/22 11:03 PM
09/21/22 11:03 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Hey all,
Hoping you can help me ID this transmission - supposed to be a 727 behind a small block. I can't seem to cross this number anywhere on the google...PK282931 7L 2540 0706
Re: Mopar transmission ID [Re: plazomat] #3079470
09/22/22 12:05 AM
09/22/22 12:05 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the date points to 1969 model year - NO partial VIN = van/truck
Re: Mopar transmission ID [Re: 6bblgt] #3079472
09/22/22 12:10 AM
09/22/22 12:10 AM
New York, USA
Chargerfan68 Offline
New York, USA
Also, the 2540 is the “ten thousand day” date code i think
And the 0706 should be the unit number of the day “i think”
Re: Mopar transmission ID [Re: Chargerfan68] #3079521
09/22/22 08:29 AM
09/22/22 08:29 AM
VA
dragon slayer Offline
VA
Part number is 2829317 L is late I believe. Hole in bell area is for timing on a van/truck/motor home.
Re: Mopar transmission ID [Re: plazomat] #3079630
09/22/22 01:14 PM
09/22/22 01:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
None of my sources show a 2829xxx, the numbers jump from 2801xxx to 2892xxx. Build date is early '69...timing hole is SB truck or van.
Re: Mopar transmission ID [Re: John_Kunkel] #3079642
09/22/22 01:51 PM
09/22/22 01:51 PM
A727Tflite Offline
A727Tflite  Offline
2829317 first appeared as a production trans for the compact truck (A100/108) in 1967.
It also appears as a production unit under the same p/n for 1968
The date code means one thing and only one thing - when the unit was made, not what model year it fits.
Looking at 2540 date code that is July 11, 1968. Tight but it could have been installed in a 1968 vehicle.
Could be a service unit for a warranty replacement back then.
Re: Mopar transmission ID [Re: A727Tflite] #3079776
09/22/22 09:54 PM
09/22/22 09:54 PM
plazomat Offline OP
plazomat  Offline OP
Thanks for the great help gents - is it worth picking up for $100 ? Comes with output yoke as well. It is for sale locally.
I would think its nothing more than a core at this point.
Plaz
Re: Mopar transmission ID [Re: plazomat] #3079811
09/23/22 12:22 AM
09/23/22 12:22 AM
A727Tflite Offline
A727Tflite  Offline
Assuming it is in good shape inside, all you need is a long output shaft and extension to use it in a car application.
As for value, depends on your locality.
Re: Mopar transmission ID [Re: A727Tflite] #3079849
09/23/22 08:32 AM
09/23/22 08:32 AM
plazomat Offline OP
plazomat  Offline OP
Thanks for all the help gents...
Plaz
Re: Mopar transmission ID [Re: A727Tflite] #3080320
09/24/22 06:00 PM
09/24/22 06:00 PM
plazomat Offline OP
plazomat  Offline OP
Picked it up today - this one must be a Frankenstein, put is side by side my other 727 that supposedly came out of an Ebody car and they are almost identical. One extra boss on the side of the known car unit.
Legnth, spine count and diameter of input - pump - and output are exactly the same...was a good buy for me - of course seller thought it was good but the fluid is black and doesn't smell too good. It was behind some twin turbo small sized diesel in a 41 1 ton dodge truck. Hope the guts aren't too bad.
Thanks again all.
Plaz
Re: Mopar transmission ID [Re: plazomat] #3080341
09/24/22 08:36 PM
09/24/22 08:36 PM
A727Tflite Offline
A727Tflite  Offline
Looking at your picture, the extension housing gasket looks a bit hokey.
Someone best you to it and made it a pass car unit.
