Well first tell us what the static sounds like.
Is it a musical whine that varies with engine speed?
(Alternator whine)
Is it a rhythmic popping which follows engine speed?
(Ignition noise)
If you have a motor or pulse type electric fuel pump, those can cause a lot of noise.
Heater/ AC/ wiper motors can all make noise, obviously you can isolate them by turning on/ off to find out which
All alternators SHOULD have a condensor / capacitor on the battery feed (output)
Your coil should have a condensor/ capacitor on the POSITIVE post
Try attaching two flexible ground straps at each rear corner of the hood to the firewall, and/ or finding --like at a two way radio shop--used to have little spring clips which you screw to the inner hood channel near the firewall. These have little ridged gizmos which, when you slam the hood, provid additional grounding
Use a good set of resistor (suppressor) spark plug wires
Make sure the radio antenna/ coax is in good shape
Sometimes bonding (ground straps) from the exhaust to the body help
