727 on engine stand? #3078769
09/19/22 03:36 PM
09/19/22 03:36 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Has anyone here ever mounted a 727 to an engine stand to work on it? Just wondering if the bellhousing would hold up where it is bolted to the stand.
Re: 727 on engine stand? [Re: 6PAX] #3078777
09/19/22 04:11 PM
09/19/22 04:11 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I did this so that it can be worked on as well. Also takes up less floor space when hanging down. I was given an old basketball hoop that I cut up to make the holder.
Re: 727 on engine stand? [Re: Jim_Lusk] #3078795
09/19/22 04:51 PM
09/19/22 04:51 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
A wheelbarrow works
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: 727 on engine stand? [Re: Bob Stinson] #3078896
09/19/22 10:32 PM
09/19/22 10:32 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I used to do Auto trans repair long ago in a previous life. Have a holding fixture similar to this. Always served me well.
https://www.amazon.com/DearChan-T-0...ef=pd_lpo_2?pd_rd_i=B09JFBZQW1&psc=1
Re: 727 on engine stand? [Re: Bob Stinson] #3078904
09/19/22 10:47 PM
09/19/22 10:47 PM
CA
crackedback Offline
crackedback  Offline
CA
Originally Posted by Bob Stinson
A wheelbarrow works
That's the best ever.
Re: 727 on engine stand? [Re: Ramrod39] #3078914
09/19/22 11:10 PM
09/19/22 11:10 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
if the shaft on that would mount in an engine stand, that would be pretty sweet.
Re: 727 on engine stand? [Re: 6PAX] #3078923
09/20/22 12:12 AM
09/20/22 12:12 AM
AndyF Online content
AndyF  Online Content
Yes, I've been using an engine stand for transmission rebuilds for at least 20 years. It makes the job much easier.
Re: 727 on engine stand? [Re: AndyF] #3078941
09/20/22 06:12 AM
09/20/22 06:12 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
A link to that bracket would be helpful.
Re: 727 on engine stand? [Re: 6PAX] #3078952
09/20/22 07:20 AM
09/20/22 07:20 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
What I was referring to with my original question was bolting the trans. directly to the engine stand like you would an engine block, not using a fixture of some sort. I've heard of some people doing so but I would think that too much stress would be put on the bell housing where it bolts up.
Re: 727 on engine stand? [Re: 6PAX] #3078954
09/20/22 07:36 AM
09/20/22 07:36 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
You dont bolt it to the bellhousing you bolt it to the tabs/lugs on the side.
Re: 727 on engine stand? [Re: 6PAX] #3078956
09/20/22 07:57 AM
09/20/22 07:57 AM
A727Tflite Offline
A727Tflite  Offline
You wouldn’t have any issues bolting it to the bellhousing.
Except restricted access to the internals.
Re: 727 on engine stand? [Re: A727Tflite] #3078964
09/20/22 08:43 AM
09/20/22 08:43 AM
an8sec70cuda Offline
iagree You'd be severely limited as to what you could do if you mounted it like that. For myself, the only time I needed a stand was when I was loading all the internals into the trans from the bellhousing end...making bolting the trans to a stand by the bellhousing completely useless. I'd rather have it laying on a bench if that was my only option.
AndyF's bracket is nice, but won't work if you're working w/ a case that has a CSR carbon shield on it when it's in the car. Those mount lugs have to be cut off the clear the shield.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 on engine stand? [Re: 6PAX] #3078982
09/20/22 10:25 AM
09/20/22 10:25 AM
I designed a bracket to bolt to the front bellhousing area but it doesn't work as well on stock transmissions as going to tabs. Going to the front works okay on a full race trans which is super light and doesn't have the tabs.
Re: 727 on engine stand? [Re: AndyF] #3079020
09/20/22 12:24 PM
09/20/22 12:24 PM
A727Tflite Offline
A727Tflite  Offline
What does the weight have to do with anything?
