Re: 1968 charger master cyl ...with power disc brakes
[Re: gtx6970]
#3077855
09/16/22 03:39 PM
09/16/22 03:39 PM
CrazyD
[Re: 6PakBee]
#3077917
09/16/22 08:12 PM
09/16/22 08:12 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
That chart is for oem units...which this is not. I know i didnt use a reman. But i cant remember which one i used back then
[Re: Mastershake340]
#3077989
09/16/22 11:23 PM
09/16/22 11:23 PM
gtx6970
It's a dry heat
Somebody was selling one with the outlets on the engine side around 10, 12 years ago. From China. I don’t think they’re available anymore. I guess you either use a 36283 and reconnoiter the lines, or rebuild what you have. To further complication matter afaik after market MC kits are not available anymore. So either look for NORS or buy a 36283 and pirate the piston assemblies to rebuild the old MC. Ok, Thanks. Ive passed said info along. And I think he is going to just buy a 36283 and buy new master cyl lines and move them to the fender side and call it done
[Re: gtx6970]
#3078004
09/17/22 02:10 AM
09/17/22 02:10 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
Weren't all the Hemi lines on the other side of both type master cylinders, drums only and rear drums with front disc brakes? Why not buy a good rebuild kit and fix that one I would
#3078013
09/17/22 07:37 AM
09/17/22 07:37 AM
Posts: 6,416 Abilene, Texas
fastmark
Abilene, Texas
Somebody was selling one with the outlets on the engine side around 10, 12 years ago. From China. I don’t think they’re available anymore. I guess you either use a 36283 and reconnoiter the lines, or rebuild what you have. To further complication matter afaik after market MC kits are not available anymore. So either look for NORS or buy a 36283 and pirate the piston assemblies to rebuild the old MC. This is what I have found. I bought a couple of spare ones back then. The only ones I’ve been able to buy lately are the fender side exit lines. The factory used engine side exit masters cly on wedge head cars and fender side exit on hemi engine cars. There has been many wedge head cars found with fender side exit masters, though,especially on Superbirds. The master cly shown in the above post are an aftermarket casting made with the ability for machining the lines for either side. Mopar never made one like that.
[Re: fastmark]
#3078020
09/17/22 08:51 AM
09/17/22 08:51 AM
Posts: 1,053 Ont, Canada
gygeneral
Ont, Canada
Im just trying to buy this 69 charger R/T and went through the pics here's the master that was on it. Dont know if that was orginal, didn't ask, but power brakes with fender pointed lines.
Ok I cant'seem to post the pic, its a web file, it says its blocked sorry
[Re: gygeneral]
#3078033
09/17/22 09:46 AM
09/17/22 09:46 AM
Posts: 10,732 North Dakota
6PakBee
North Dakota
Just throwing this out, in '67 if you ordered power disc brakes in a 'B' body you got the "Hemi" booster with the "Hemi" master cylinder. Here is a '67 GTX with a 440 and power front discs.
[Re: gtx6970]
#3078146
09/17/22 04:08 PM
09/17/22 04:08 PM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
Bill my '69 GTX's power disc brake master cylinder that I'm certain is the original. SPD December 16, 1968. The second image is how it was when I bought the car from the original owner. I'll check when I get a chance later for the part number. Mike
[Re: dragon slayer]
#3147410
05/29/23 12:13 PM
05/29/23 12:13 PM
A12
N.E. OHIO, USA
Yes you can get kit, though I think they started to get scarce. If your pistons are good, you can also get seals. Orig and orig replacements were 1 1/18" bore.
Below is the data on mc. C body used theses too. The difference was pistons installed. Though you probably would not notice any difference. These are all Bendix units. 2881868 MC Casting 2225621 to Fender 67 All B Body and 68 B with Hemi 4 Piston Bendix 2881870 MC Casting 2226811 to Fender 67-68 C Body Fat and Tall 4 Piston Budd 2883058 MC Casting 2226821 to Engine 68-69 B Body without Hemi 4 Piston Bendix #1 2944269 MC Casting 2226821 to Engine 68-69 B Body Station Wagon Power Drum #2 2944376 MC Casting 2225621 to Engine 69 B Body with Hemi 4 Piston Bendix #3 2883089 MC Casting 2225621 to Fender 69-70 C Body Floating Single Piston Calipers 2944476 MC Casting 2229191 to Fender 70-71 B/E Body with Hemi Fat and Short #4 2944477 MC Casting 2226821 to Engine 70 B Body without Hemi Floating KH Single Piston Caliper #5 2944479 MC Casting 2225621 to Fender 70 B Body Taxi Manual Disc has studs
THANK YOU Is there a way to determine a rebuild kit part number for a specific casting number or do I search by the master cylinder (i.e., 2883058 MC) number or the casting numbers you provided? I would need a rebuild kit for: 2883058 MC Casting 2226821 to Engine 68-69 B Body without Hemi 4 Piston Bendix ('69 GTX 440, front power disc brakes) There are a few listed on eBay but until I take my MC off and apart I don't know what I need to start looking for. On the other hand, I will need to take it apart first to confirm what I need, (duh) but a rebuild kit part number may get me into the right area to search. Thanks, Mike
[Re: A12]
#3147574
05/30/23 11:20 AM
05/30/23 11:20 AM
Posts: 1,328 VA
dragon slayer
VA
I guess I should start a go fund me page. This is all top secret info I compiled Remember me when I ask a question. Disc Brakes Repair Kits for 1 1/8” Bore 2808616 MC Kit with 792 Silver/793 Green Pistons 67-68 B Body All Mk662 2808617 MC Kit with 749 Silver/751 Green Pistons 67-68 C Body; Guide on 749 Spring Mk503 #1 3420002 MC Kit with 792 Silver/793 Green Pistons 68-69 B Body Station Wagon Power Drum Mk662 #2 3420117 MC Kit with X/X Pistons 69 B Body and 69 B with Hemi Mk662 3420120 MC Kit with 749 Silver/6877 Gold Pistons 69-70 C Body Mk620 3420967 MC Kit with 749 Silver/6877 Gold Pistons 70 B Body Non-Hemi Mk620 3420968 MC Kit with 9194 Silver/6877 Gold Pistons 70-71 B & E Body Hemi None 3420969 MC Kit with 9174 Gold/748 Green Pistons 70 E Body Non-Hemi 1” Bore None 3420980 MC Kit with X/X Pistons 70 Taxi Manual Disc None #1 3420002 Has identical pistons as 2808616, but has 2 residual valves since Drum/Drum setup #2 3420117 May have superseded 2808616 with same pistons; since brake system remained the same
[Re: dragon slayer]
#3147577
05/30/23 11:29 AM
05/30/23 11:29 AM
A12
N.E. OHIO, USA
I guess I should start a go fund me page. This is all top secret info I compiled Remember me when I ask a question. Disc Brakes Repair Kits for 1 1/8” Bore 2808616 MC Kit with 792 Silver/793 Green Pistons 67-68 B Body All Mk662 2808617 MC Kit with 749 Silver/751 Green Pistons 67-68 C Body; Guide on 749 Spring Mk503 #1 3420002 MC Kit with 792 Silver/793 Green Pistons 68-69 B Body Station Wagon Power Drum Mk662 #2 3420117 MC Kit with X/X Pistons 69 B Body and 69 B with Hemi Mk662 3420120 MC Kit with 749 Silver/6877 Gold Pistons 69-70 C Body Mk620 3420967 MC Kit with 749 Silver/6877 Gold Pistons 70 B Body Non-Hemi Mk620 3420968 MC Kit with 9194 Silver/6877 Gold Pistons 70-71 B & E Body Hemi None 3420969 MC Kit with 9174 Gold/748 Green Pistons 70 E Body Non-Hemi 1” Bore None 3420980 MC Kit with X/X Pistons 70 Taxi Manual Disc None #1 3420002 Has identical pistons as 2808616, but has 2 residual valves since Drum/Drum setup #2 3420117 May have superseded 2808616 with same pistons; since brake system remained the same Your secret's safe with me, I won't tell anybody if you don't THANK YOU this helps greatly Mike
