69 Dart Fenders on a 67 Dart? #3077745
09/16/22 09:22 AM
09/16/22 09:22 AM
Spanaway, Washington State
P
patosmith Offline OP
P
I have a 67 Dart that is in need of good front fenders.
I have contacted AMD. They don't plan to produce any 67 fenders. They have one 68 fender and both 69 fenders in stock.
Will the 69 fenders work on my 67? Yes, I know I will need to fill in the side marker light openings.
I am mainly concerned about the fenders being compatible with the 67 headlights and grill.
I could talk to AMD but I wanted to reach out to the Mopar nation first to see if anyone has any input.
Thanks in advance!
Re: 69 Dart Fenders on a 67 Dart? [Re: patosmith] #3077900
09/16/22 06:37 PM
09/16/22 06:37 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
'69 headlight buckets are not in the correct location (or so I've been told) for a '67 or '68.
Re: 69 Dart Fenders on a 67 Dart? [Re: Jim_Lusk] #3077906
09/16/22 07:09 PM
09/16/22 07:09 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree
Master, again and still
Re: 69 Dart Fenders on a 67 Dart? [Re: DaveRS23] #3077913
09/16/22 07:57 PM
09/16/22 07:57 PM
P
P
Thanks for the response!
I guess i wait to see if AMD repops some more 68 fenders.
Re: 69 Dart Fenders on a 67 Dart? [Re: patosmith] #3078606
09/18/22 11:45 PM
09/18/22 11:45 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
68 fenders are even further out than 67 or 69, they are by themselves. There were lots of differences in the headlight bucket area for all three years. I bought an 11,000 mile 69 Dart from the original little old lady owner and something seemed off on the front. When I got it home I noticed it had a 67 fender on the passenger side, the 69 headlight bezel was off by about an inch, so I am sure visa versa would be the same. I have a pair of each fenders, grilles, and headlight bezels laying around, I need to bolt them all on a spare body I have and see what the real differences are...
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 Dart Fenders on a 67 Dart? [Re: Rhinodart] #3078661
09/19/22 10:02 AM
09/19/22 10:02 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Not that long ago, I was fixing up a '68 Dart 270. The right side had been hit and fixed long ago. The right fender had been replaced apparently with a new one and the Chrysler part number was still visible inside the fender. Now clearly the fender was not originally built for a '68. The headlight bucket was moved/replaced. And the top of the fender above the headlight was different than the '68s. I have always wondered if it came that way from Mopar or had been modified at a shop.
Re: 69 Dart Fenders on a 67 Dart? [Re: patosmith] #3079551
09/22/22 10:05 AM
09/22/22 10:05 AM
Canada
demon Offline
demon  Offline
Canada
the 1969 Dart fenders have the headlights mounted up and further back than the 67-68. The whole headlight mounting panel area is altogether different
Re: 69 Dart Fenders on a 67 Dart? [Re: demon] #3079661
09/22/22 03:01 PM
09/22/22 03:01 PM
moparx Offline
moparx  Offline
i was under the impression you could the complete nose [67, 68, 69, 70, etc] assembly on all darts up to around 73 or so ? shruggy
in other words, the panels would bolt on, but in order to fit and look correct, you need to use all the like year parts. [fenders, hood, grille, etc.]
beer
Re: 69 Dart Fenders on a 67 Dart? [Re: moparx] #3079753
09/22/22 08:41 PM
09/22/22 08:41 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
beer
Yes, entire doghouses are interchangeable except that in late 69 there were tabs added for the upcoming lower valance for the 70-72 Dart and Demon on the lower core support, if your body does not have those tabs then you have to figure out how to mount the valance... work
A-Body's RULE!
Re: 69 Dart Fenders on a 67 Dart? [Re: Rhinodart] #3083268
10/04/22 03:21 PM
10/04/22 03:21 PM
moparx Offline
moparx  Offline
thanks for confirming that Rhino. up
beer
