Collector Size #3077195
09/14/22 11:59 AM
09/14/22 11:59 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
I'm going to be building my own set of fenderwell headers with 1 7/8 primary tubes should I use a 3 or 3 1/2" collector? Race only engine, Big block 440 see's 6500 rpm max, est 525-550 engine HP.
Re: Collector Size [Re: DusterKid] #3077201
09/14/22 12:12 PM
09/14/22 12:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've been down that road more than once, on your deal with that motor combination in my A body cars liked the Hooker A body fenderwell headers with the 2.0-inch primary pipes with 3.5 inch or larger collectors for all out drag racing better than the 1 7/8 inch set with the same collector size: up: shruggy twocents
You know you're going to want to make more power later so build the big pipe set now and not have to do it over later work scope
Re: Collector Size [Re: Cab_Burge] #3077358
09/14/22 10:43 PM
09/14/22 10:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Though I've never tried a larger collector mine has made plenty of power using 3.5". And that's with a 580" motor that sees 7300rpm. I doubt if you need 3.5" with your combo.
Doug
Re: Collector Size [Re: Cab_Burge] #3077376
09/14/22 11:49 PM
09/14/22 11:49 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I agree w Cab on the tube size. Also on the collector, start with at least18 inches in length and shorten from there if you need to.
Old Geezer Racing
Re: Collector Size [Re: SCATPACK 1] #3077414
09/15/22 08:33 AM
09/15/22 08:33 AM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
I was told by my father and his buddies who raced S/S back in the 60's to start with a Longer (24"?) Collector - paint it a light cheap black color and after 5-6 runs the paint will burn off to where we should cut them off.
Does anyone still use this theory?
I happen to have a new set waiting to use on my Demon that I just (lightly) painted.
Not trying to hijack - just asking to hopefully help.
Thanks to the OP for this post!!
Wally.
Re: Collector Size [Re: wkroncke17] #3077421
09/15/22 09:02 AM
09/15/22 09:02 AM
PA
moparacer Offline
moparacer  Offline
PA
I would run 3 1/2 if it were me....1 7/8 is kind of on the border line though. Anything smaller I would run the 3 inch.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Collector Size [Re: moparacer] #3077461
09/15/22 10:42 AM
09/15/22 10:42 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Somewhere I have my Headers by Ed design documents that go into details on tube sizes, collector size ratios vs tube size, etc.
What I recall is based on Ed's formula, a 1-7/8" with a 3.0" collector is pretty much right in the middle of his acceptable range; a 3.5" is pretty big for that tube size, unless you're turning a lot of RPM and/or narrow RPM range (stick car vs auto).
With 2" tubes, a 3.5" is also pretty much right in the middle of his acceptable range. I've only seen one prod header that I remember 2" tubes and 3.0" collector, and that was a Hedman Header model which I never considered.
A 3.0" for a 2" tube is definitely on the small side, although in a merge collector it could taper down to 3.0" before expanding back to 3.5". But everything I've heard says you should design that from the start, not just slap a merge collector on a header not designed for one... even though I see that's what a number of header companies do now cuz it's simpler that way.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Collector Size [Re: Brad_Haak] #3077499
09/15/22 12:52 PM
09/15/22 12:52 PM
moparx Offline
moparx  Offline
if running a 3 1/2" collector into a full exhaust system, and the collector is 3-6" long on the header, would it be of benefit to run 3 1/2" pipe to the x, then reduce to 3" [at the x pipe] for the rest of the exhaust system ?
beer
Re: Collector Size [Re: DusterKid] #3077502
09/15/22 12:54 PM
09/15/22 12:54 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Respectfully, I wouldn't build fenderwell headers until you NEED to poke them out the fender. e.g.- OVER 1000HP Plenty of room to accommodate 2" or larger in a b eng a-body and do it clean and 'correct'. Also, if you're building custom just use 2" x 3.5" IMO OR BUY the TTI. While I dont like them, they seem to work pretty OK!
Re: Collector Size [Re: wkroncke17] #3077509
09/15/22 01:04 PM
09/15/22 01:04 PM
I was told to use a crayon to mark the collector extensions and run the car several runs and to cut the collector off where it melts the crayon shruggy
I've never done that but every Mopar, stick or automatic car, I've added collector length to went faster and quicker so test, test and test some more wrench up twocents
Re: Collector Size [Re: HardcoreB] #3077534
09/15/22 02:13 PM
09/15/22 02:13 PM
Keymar, MD
Keymar, MD
Car had 2" hooker fenderwell on it for years. We than added snout bars and for whatever reason the way we did it interfered with the headers, but at the same time I bought a set of TTI 2" headers as I wanted to run a larger front tires after years of red lighting. Used them for a good many years, but absolutely HATED working on the car with them. Yes they fit great once on, but man they were miserable especially the trans bell bolts. I ended up putting TTI 1 3/4" headers on the car as I had them and was over working with the 2" ones. Used them for a few years but felt they were a little small for my engine, so I modified the old Hooker 2" fenderwells so they would clear the snout bars. I did the swap over the winter but didn't change anything else in the process. Comparing time slips for the 1 3/4" TTI vs Hooker 2" it seems the 60fts are the same, but MPH may actually been slightly better with the TTIs. The TTI's did have a 18" glasspack muffler vs the Hooker 6" Schoenfeld Race Mufflers. I ran each for atleast 2 seasons, so have a decent data base to compare to, but didn't make a ton of passes (only made about 30 this year). I'm to the point that I don't want to mess with underchassis headers as I've been spoiled by the ease of fenderwell headers, but also I'm tired of my front tires rubbing. The header flanges have been welded up and need replaced on the hooker as they are about 25 years old.
Re: Collector Size [Re: DusterKid] #3077562
09/15/22 04:03 PM
09/15/22 04:03 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
In the late 70s we ran a 413 stocker with 2 inch adjustable hookers and 3.5 collectors.One weekend we substituted 3 inch Stahl collectors just because we had them and were curious. The results were stunning. Can't remember exactly how much better but we never went back. Of course the craftsmanship was much better in the Stahl collectors. The collectors on my current motor are junk compared to those old Stahl pieces so I will only suggest you look for guality as well as size in today's parts market
62 Dodge Dart Wagon 65 Plymouth Satellite
