thanks guys ! i knew you would come through !
i had forgotten about Dante's !
in the 70's, i did several headliners, as well as a few other simple items such as door panels.
these were custom items however, and nothing remotely close to a restoration.
i'm not sure my old bones could fold around enough to do a headliner these days, but i can certainly coach a young buck through a quality installation.
the one thing that is very confusing to me, is why are there so many variations of the same color [in this instance, "brite blue" i think it's called] of materials used ?
i can see the molded plastic parts being different, but the arm rests being slightly off from the seat color, being slightly off from the dash pad ?
i realize different vendors having different shades of the same "material", but being off enough to stick out like a sore thumb seems odd to me.
could buying from the same outfit make the color match a bit closer ? or should the colors just be off "because" ?
