Kokomo trans plant workforce on strike, AC one issue
#3076065
09/10/22 02:42 PM
09/10/22 02:42 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Re: Kokomo trans plant workforce on strike, AC one issue
[Re: Uberpube]
#3076170
09/10/22 10:01 PM
09/10/22 10:01 PM
Posts: 15,427 Omaha Ne
TJP
Omaha Ne
[Re: J_BODY]
#3076214
09/11/22 01:43 AM
09/11/22 01:43 AM
Posts: 712 Southern Alberta
Uberpube
Southern Alberta
When’s the last time you saw something “made in Japan”…. The Okonomiyaki sauce I had with dinner.
[Re: Dart 500]
#3076259
09/11/22 10:11 AM
09/11/22 10:11 AM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
My employer had an assembly plant near Dallas and part of my onboarding when I got hired as an engineer was working there for two weeks on the line. I was there in April and it wasn’t bad, but the previous hire group went there the previous august during a heat wave when it was 100+. People at the plant said when real hot it was miserable, even by a fan didn’t help. That plant got closed not long after, but we’re building a new plant in San Antonio. I’m not sure if there’s any climate control there. At a previous employer I visited both iron and aluminum foundries. The Kansas aluminum foundry in particular sticks in my memory, we visited it in summer, and the workers were dressed in heavy denim and gloves to protect against splatters of molten aluminum. In the iron foundry, I was told the guy manning the hot crucible of molten iron was one of the most coveted jobs in the plant. I see service centers and wonder how the techs deal with summer heat as most of those places aren’t air conditioned. But then I see roofers and think that’s got to be the worst job in the world! I’m not very heat tolerant especially humidity, and work an office job in AC. But I have had no shortage of chest puffing friends and coworkers tell me they thrive in summer heat and humidity and I’m a pussy for saying it messes me up. Obviously some people are really heat tolerant, I’ve known many others who can’t deal with bitter cold. I don’t like it but I do fine with it. We had a bitter cold snap a few years ago where it hit -25. I told myself if my car started, I was going into the office. It started so off I went. It was like a neutron bomb had gone off, roads were empty. Only a handful of coworkers showed up to work. I rolled my eyes that the no shows were so weak. So if you can’t handle heat, don’t work in a factory, garage, as a roofer, building roads etc. Theres lots of different careers out there and people need to work in jobs that suit their physical abilities and limitations.
[Re: Mastershake340]
#3076273
09/11/22 11:36 AM
09/11/22 11:36 AM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
Stellantis switching to EV is probably a bad time for a transmission plant to go on strike it would seem.
[Re: slantzilla]
#3076324
09/11/22 03:19 PM
09/11/22 03:19 PM
Posts: 10,589 Freeport IL USA
poorboy
Freeport IL USA
Years ago I worked in factory maintenance in two different forge shops, one for 7 years in a plant producing mainly brass and aluminum forgings, and the other for 6 years that mostly did steel forming for farm equipment. In both factories the temp surrounding the operators at both ends of furnaces that heated the metal was 130 degrees through the summer months and around 75 degrees through the winter months. The loading end of the furnace was a better position then the unloading end where the forge operator worked. The load end paid a one step up in the wage scale then most of the floor work stations, and the operator end paid another pay scale step up, which was nearly the highest paid position in the plant. Both positions were highly valued and had a waiting list of people ready to step into the position. For the operator end, they couldn't even have a fan pointed directly at them without effecting the temp of the heated slug, having AC at that point would have been foolish. Any job position more then 10' away from the furnace was 20 degrees cooler, and every foot farther away reduced the temps even more. The part of the buildings where the forge furnaces were, were separated from the rest of the building. Those forge furnaces provided most of the heat to the rest of the plant, iIn the winter, you really wanted to be in the forge furnace section of the plant. Most people outside of the forge section wore heave sweatshirts and light jackets and gloves during the winter.
As for the UAW strike during this time frame? I suppose they figure it may be their last hope to have a strike unless they can get into the new plant. The labor unions are no longer there to assist the working man, they are now there to collect money to support the political party of their leader's choice, and assist those that really don't want to work.
[Re: 360view]
#3076724
09/12/22 09:08 PM
09/12/22 09:08 PM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I worked at a foundry for 2 years in the late 80s. I was 19 years old. I simply could not do that now at 53- or rather would only do it it if it were my ONLY option. So us older folk don't cope well with heat and humidity but the young current generation does not either. Even here in my home town the climate controlled facilities- LG Chem the biggest cannot attract and retain workers.
Keep old mopars alive.
