NAG1 identification #3075026
09/07/22 07:54 AM
09/07/22 07:54 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Does anybody have an idea on how to identify a NAG1 transmission?
Most of them have a barcode on the driver side, but I cannot find any information on identifying them.
I know the NAG1 is also called 722.6 / a5w580, but there seems to be a difference between the Mercedes and Chrysler transmission. Trans code for Chrysler is DGJ. There seems to be a diffence between transmission and the last two digits after 722.6XX can give clearance. However I cannot find any number on the transmission itself besides the barcode on the driver side.
Re: NAG1 identification [Re: dickdale] #3075040
09/07/22 08:46 AM
09/07/22 08:46 AM
south louisiana
lowell66dart Offline
south louisiana
Don't have a clue but a quick search turned this up. Google transmission-sales-code-chart.pdf - Mopar Repair Connect
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: NAG1 identification [Re: lowell66dart] #3075401
09/08/22 07:52 AM
09/08/22 07:52 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
thx! But were can I find this on the transmission?
Re: NAG1 identification [Re: dickdale] #3076038
09/10/22 12:24 PM
09/10/22 12:24 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I got this from charger forum
NAG1; W5A580
The transmission can generically be identified by the presence of a round 13-way connector located near the front corner of the transmission oil pan, on the right side. Specific transmission information can be found stamped into a pad, above the oil pan rail, on the left side of the transmission
Facts are stubborn things.
Re: NAG1 identification [Re: larrymopar360] #3076118
09/10/22 06:57 PM
09/10/22 06:57 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
If you're in Europe its probably from a Mercedes, guys here are giving data from the 05-2014 Mopar ones
They probably had different variations over there, they even used one in the S65 which would not have been a standard one. Regular ones from memory were only rated for around 420~ lb ft of torque
Re: NAG1 identification [Re: Dart 500] #3079823
09/23/22 04:55 AM
09/23/22 04:55 AM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
Found out that a NAG1 from a Chrysler is almost the same as from a MB. The difference is the clutch pack.
The AMG ones have double sided friction plates. The Chrysler ones have single sided plates. The AMG also has Blue Top Shift Solenoids for firmer shifts as the Chrysler has brown top solenoids. And of course the bellhousing is different between both of them.
Re: NAG1 identification [Re: dickdale] #3083447
10/05/22 06:38 AM
10/05/22 06:38 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Back in 2010 when I had an SRT Challenger the blue tops were a good upgrade.
