Crossram for low deck #3075635
09/08/22 09:25 PM
09/08/22 09:25 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
What are my options for a 400 (500ci) crossram with Max Wedge ported Indy SR's??
Re: Crossram for low deck [Re: Hyper Henry] #3075639
09/08/22 09:33 PM
09/08/22 09:33 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The old STR15 is the only option I know of.
They generally fetch $2k when the pop up, and they are far from ideal as a performance piece.
Re: Crossram for low deck [Re: dizuster] #3075643
09/08/22 09:40 PM
09/08/22 09:40 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Can the STR be ported to max wedge?
Re: Crossram for low deck [Re: GomangoCuda] #3075683
09/09/22 01:47 AM
09/09/22 01:47 AM
[quote
Can the STR be ported to max wedge? [/quote] Not the entire length of all the runners twocents
I would look at Indy Cylinder Heads and see if they make a low deck motor M.W. base with a removable top scope If so buy their cross ram top and have some fun up wrench
BTW, one of the first multiple carb motors I built for someone else was a early 383 with iron heads that we had bigger valves put in them with stock intake and exhaust port sizes with a low deck STR manifold with the original crossram top with two Holley 600 or maybe 650 CFM D.P. carbs, Isky 505T solid roller cam with a stock early 1962 727 trans and converter, that combination was a dead dog under 3500 RPM and then it turned into a real monster shock
The owner had agreed to using a good BM O69J converter and a lot of other good drag race parts at the start of the build and then renege when it came time to buy the other good parts rant pukewhiney
I had that happen more than once since then also shruggy
Re: Crossram for low deck [Re: Hyper Henry] #3075689
09/09/22 04:42 AM
09/09/22 04:42 AM
AndyF Offline
AndyF  Offline
I don't know of any low deck cross ram intakes. There are not very many low deck MW intakes period. The Indy 400-3 might be the only one available at the moment. It isn't a great intake but Wilson Manifolds can turn it into something that really works.
Re: Crossram for low deck [Re: AndyF] #3075736
09/09/22 10:10 AM
09/09/22 10:10 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Mopar Stage VI heads and an A&A crossram.
Re: Crossram for low deck [Re: fbs63] #3075748
09/09/22 10:53 AM
09/09/22 10:53 AM
AndyF Offline
AndyF  Offline
Yeah that combo would fit together but you'll spend a lot of money without making a lot of power.
Re: Crossram for low deck [Re: AndyF] #3075868
09/09/22 06:27 PM
09/09/22 06:27 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I agree! Cross rams look cool but are wanting in performance.
Re: Crossram for low deck [Re: fbs63] #3075874
09/09/22 06:55 PM
09/09/22 06:55 PM
AndyF Offline
AndyF  Offline
Yeah I used to think that the cross ram was the way to make power since that was what the factory used on the MW cars but after we did a series of dyno tests I decided that a well designed single plane intake makes more power, I never tested a custom built sheet metal cross ram so perhaps one of those would work even better.
Re: Crossram for low deck [Re: AndyF] #3075919
09/09/22 09:25 PM
09/09/22 09:25 PM
Ontario, Canada
Ontario, Canada
I already have a new Indy single 4150 intake for low deck but love the look of a crossram. Not sure I want to loose a bunch of HP though confused
Re: Crossram for low deck [Re: Hyper Henry] #3076060
09/10/22 02:02 PM
09/10/22 02:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The cross-ram (413 Chrysler F, G 413 RB; 383 B, MW) was specifically designed with runner length to add torque based on the engine's power rage (2,800 and 5,500?). Small plenums, small carburetors, and high velocity in the runners. Since the left and right manifolds are separate castings, an original manifold ($$$!) will bolt to any B/RB engine, shorten and re-attach the runners to your calculations.
I spent many happy hours in an air-conditioned 300F convertible back in the day, and its "manners" never betrayed the plumbing under the hood.
Too long for big cams an good heads.
What would a manifold be with runner length tuned for 7,000?
Tunnel ram - the runners just extend vertically.
The Weiand 6-Pack offers some ideas, see my comments here: http://victorylibrary.com/mopar/weiand.htm
Boffin Emeritus
Re: Crossram for low deck [Re: polyspheric] #3076091
09/10/22 04:50 PM
09/10/22 04:50 PM
You forgot to mention that Chrysler made three different intake runner lengths from 1959 to 1964 in the 300 Letter cars, long length with the divider from the carb plenum to the heads, medium length runners with a small amount of the divider wall removed near the heads and the shortest ones that had no wall between the runners up to around the middle of the manifolds from the heads: scope:
I think the last ones where the shortest ones and probably made the best combination of power from the idle and low RPM (under 2500 RPM) light part throttle operations up to wide open throttle work twocents
Re: Crossram for low deck [Re: Cab_Burge] #3076479
09/12/22 07:50 AM
09/12/22 07:50 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
What happened to you running the Modman? I think it has potential and we'll know soon. With the runner extensions, I'd put it ahead of a single 4 in power. That is with 2 AFB's.
