TF 240 cnc program
#3072625
08/30/22 02:32 PM
08/30/22 02:32 PM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
Does anyone have a cnc program to take the 240 heads to max wedge?
Also need my roller cam repaired. Who could I send it to. It's a Howards..It looks a little rough.
Thanks, Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
Re: TF 240 cnc program
[Re: 605ply]
#3072674
08/30/22 04:19 PM
08/30/22 04:19 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
...sell your 240's and buy 270's I hear they recently went up 200.00 per head.
[Re: 605ply]
#3072735
08/30/22 06:18 PM
08/30/22 06:18 PM
Posts: 4,680 Wichita
GY3
Wichita
440Source has 270's in stock.
[Re: 69Mcode440]
#3072865
08/31/22 10:30 AM
08/31/22 10:30 AM
Posts: 1,131 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Plenty of competent head porters can open a standard port to MW; doesn't require a CNC program. Have you contacted Howard's about the cam? Depending upon the issue, it may not be cost-effective to try and repair it.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3073014
08/31/22 07:28 PM
08/31/22 07:28 PM
69Mcode440
Cedar Rapids, IA
Thanks for the ideas.
Mike
