a230 input retainer swap
#3072068
08/28/22 12:51 PM
08/28/22 12:51 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Can the input shaft retainer from and A230 swap to say a 69 23 slpie 4 speed.Have a good one on the 3 speed and used the one from the 4 speed on m,y 65 trans.Thanks
Chrysler Firepower
Re: a230 input retainer swap
[Re: Alaskan_TA]
#3072141
08/28/22 06:27 PM
08/28/22 06:27 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
They both use a 307 bearing and small register on the bellhousing. I have an A833 input and an A230 input on the shelf and the input shafts look identical. I would say yes they would but I have never personally tried it. Rocky if yours is broken I probably have a good used one for you. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3072258
08/29/22 12:37 AM
08/29/22 12:37 AM
therocks
Niles , Ohio
Thanks Gus I used the one from the 69 trans on my 65 tranny.Just if the 230 will work Ill keep it as they are pricey new.Still have to find someone to look at the 69 trans I know it needs a shifter fork and ?Got it from a friend and its been sitting since like 70 or so
Chrysler Firepower
[Re: fourgearsavoy]
#3072583
08/30/22 11:34 AM
08/30/22 11:34 AM
therocks
Niles , Ohio
Gus when I get a few bucks Ill drop it off.Have no idea whats wrong or it was just a broken shifter fork Thanks
Chrysler Firepower
