Ignition Module Mess Clean Up #3071928
08/27/22 08:42 PM
08/27/22 08:42 PM
PA
dodgeman316 Offline OP
PA
The ignition module on my car puked it's guts all over the inner fender.
Anyone have experience with cleaning that stuff up?
What works best to get it off?
Re: Ignition Module Mess Clean Up [Re: dodgeman316] #3071953
08/27/22 10:28 PM
08/27/22 10:28 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That's nasty stuff to clean up. Most mild solvents don't do much. Stronger (lacquer/acetone) will work, but not so good on the paint there.
You might try Spirits with a softer scouring pad. May require some elbow work, but time consuming.
I sealed the rears of some I had with Glyptol coating.
Re: Ignition Module Mess Clean Up [Re: PhillyRag] #3071956
08/27/22 10:38 PM
08/27/22 10:38 PM
VA
dragon slayer Offline
VA
Heat can help soften it, and acetone will clean it up, but your paint is at risk. So use heat to soften, and something easier on paint as mentioned.
Re: Ignition Module Mess Clean Up [Re: dragon slayer] #3071996
08/28/22 08:44 AM
08/28/22 08:44 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Steam cleaner.
Re: Ignition Module Mess Clean Up [Re: 6PakBee] #3072194
08/28/22 08:35 PM
08/28/22 08:35 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Originally Posted by 6PakBee
Steam cleaner.
That will certainly softer it, but problem is removing the residue of it.
Re: Ignition Module Mess Clean Up [Re: PhillyRag] #3072197
08/28/22 08:40 PM
08/28/22 08:40 PM
PA
PA
Thanks for the ideas.
I used a heat gun to warm it up and then used one of those nylon tools for removing trim panels to scrape off the worst of it.
I then used some mineral spirits to remove the residue. It took a little scrubbing but seemed to work ok and it does not appear to have damaged the paint.
Re: Ignition Module Mess Clean Up [Re: dodgeman316] #3072268
08/29/22 06:49 AM
08/29/22 06:49 AM
VA
VA
Good to hear.
Re: Ignition Module Mess Clean Up [Re: dodgeman316] #3072282
08/29/22 08:53 AM
08/29/22 08:53 AM
Alabama
W
WarEagle1 Offline
WarEagle1  Offline
W
Alabama
I soaked some shavings of that potting in 4 or 5 different solvents I had in the shop to see what might dissolve it (I skipped lacquer thinner because I didn't want to destroy the paint). Nothing was highly effective but plain ole gasoline was the best. I used gas in a squirt bottle and a plastic putty knife. And a LOT of tedious, careful scraping. Took an hour plus, but I got it all off.
