Re: Need 4.50 bore sleeves for mega block
[Re: mercman1]
#3071715
08/26/22 09:31 PM
08/26/22 09:31 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
What little info I collected pointed to Darton Sleeves as being good. Just be sure and go thick enough to do your motor justice. How bad/thin are your current cylinders?
[Re: gregsdart]
#3071817
08/27/22 12:57 PM
08/27/22 12:57 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
What little info I collected pointed to Darton Sleeves as being good. Just be sure and go thick enough to do your motor justice. Call Darton and see what they have for your motor. I'm not sure if they offer both steel and ductile iron sleeves for your deal but if they do get the ductile iron sleeve
[Re: mercman1]
#3071831
08/27/22 01:36 PM
08/27/22 01:36 PM
Posts: 3,023 NY
B1duster
NY
[Re: dvw]
#3071862
08/27/22 03:30 PM
08/27/22 03:30 PM
Posts: 8,299 fredericksburg,va
cudaman1969
fredericksburg,va
I had my Mega block sleeved last year. Rod broke and piston jammed cracking #3. Standard replacement sleeve. Now it's 4.530" 15-1. No issue with head gaskets. In fact its gone quicker than before it was fixed. It has50 passes so far. No water leaks, it has good power. Ive been pleased with it. Price 8 Darton sleeves and labor. Ouch. Fix what is necesary and move on. Doug Hemi or wedge, what type gasket, who’s piston?
[Re: B1duster]
#3072013
08/28/22 10:01 AM
08/28/22 10:01 AM
Posts: 9,861 MI, usa
dvw
MI, usa
DVW —- What brand/type rod broke ? Spun bearing ? It was a Molnar rod It wasn't the fault of the rod itself. It spun a bearing. Probably made it through at least 2 passes after the damage started before it broke. My fault I knew something was wrong at kept running it. It has Molnar stuff in it again. Doug
[Re: cudaman1969]
#3072014
08/28/22 10:07 AM
08/28/22 10:07 AM
dvw
MI, usa
I had my Mega block sleeved last year. Rod broke and piston jammed cracking #3. Standard replacement sleeve. Now it's 4.530" 15-1. No issue with head gaskets. In fact its gone quicker than before it was fixed. It has50 passes so far. No water leaks, it has good power. Ive been pleased with it. Price 8 Darton sleeves and labor. Ouch. Fix what is necesary and move on. Doug Hemi or wedge, what type gasket, who’s piston? Indy wedge. It had Diamond flat tops. .051" Cometic gaskets. Now has Ross Flattops, .060" Cometics. Been 8.98@149/ 3340lbs. Recently at 1/8 track it went .06 quicker in 660 then that run. Doug
[Re: dvw]
#3072018
08/28/22 10:17 AM
08/28/22 10:17 AM
cudaman1969
fredericksburg,va
I had my Mega block sleeved last year. Rod broke and piston jammed cracking #3. Standard replacement sleeve. Now it's 4.530" 15-1. No issue with head gaskets. In fact its gone quicker than before it was fixed. It has50 passes so far. No water leaks, it has good power. Ive been pleased with it. Price 8 Darton sleeves and labor. Ouch. Fix what is necesary and move on. Doug Hemi or wedge, what type gasket, who’s piston? Indy wedge. It had Diamond flat tops. .051" Cometic gaskets. Now has Ross Flattops, .060" Cometics. Been 8.98@149/ 3340lbs. Recently at 1/8 track it went .06 quicker in 660 then that run. Doug Nice
