Typical header tube temperature at idle? #3071626
08/26/22 01:59 PM
08/26/22 01:59 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
What is a typical temperature for header tubes at idle? On my hot rod Coupe, it is 140 on the left bank and 450 on the right bank. Obviously one of them isn't right, and I'm thinking it is the left bank. Maybe my idle circuits are plugged so I'm not getting much combustion at idle? Either that or the right side idle circuit is plugged so that side's running really lean and thus hot?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Typical header tube temperature at idle? [Re: Hemi_Joel] #3071629
08/26/22 02:07 PM
08/26/22 02:07 PM
It depends on which fuel and idle RPM.
I would try swapping the carbs from side to side and see if its them or maybe a vacuum leak on the intake scope twocents
I can't remember now if you have Stromberg Carlsons, Holley carbs or the other brand that I can't think of right now blush Either way they are fixable, it is a matter of figuring out which part needs fixing, idle circuit, transition circuit, float level or????
Good luck, let us know what you find wrench: up
Re: Typical header tube temperature at idle? [Re: Hemi_Joel] #3071633
08/26/22 02:29 PM
08/26/22 02:29 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Your Skin Should Stick!
Sorry for the Friday Humor/
Re: Typical header tube temperature at idle? [Re: RATTRAP] #3071652
08/26/22 03:50 PM
08/26/22 03:50 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I see 450-500*F at idle typically on every tube, I check it about an inch from the flange with an IR gun. Do you have thermocouples, or was that an IR reading?
If that 150*F is real, those cylinders aren't contributing anything.
Re: Typical header tube temperature at idle? [Re: Hemi_Joel] #3071653
08/26/22 03:51 PM
08/26/22 03:51 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
If I had a cylinder that was at 140 degrees idling, I would suspect that it's not firing.
Joe
Without Data, you’re just another guy with an opinion.
Re: Typical header tube temperature at idle? [Re: sr4440] #3071656
08/26/22 04:15 PM
08/26/22 04:15 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Intake manifolds are a mess at idle with large cams and overlap. I'd rev it up to 2500 or so and see how they look.
68 Barracuda Formula S 340
Re: Typical header tube temperature at idle? [Re: Bad340fish] #3071658
08/26/22 04:18 PM
08/26/22 04:18 PM
Minnesota
Minnesota
It is gasoline, 1500 idle, big cam. 8 carbs on a crossram, each side has its own plenum with 4 carbs, 2 of which have idle circuits. I'll rev it up enuff to get it off the idles circuits and recheck.
HF IR temp gun.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Typical header tube temperature at idle? [Re: Hemi_Joel] #3071669
08/26/22 05:15 PM
08/26/22 05:15 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Yep with a heat gun on the outside of the tube at idle I see 400 to 600 degrees depending on the engine. If you have a cylinder a couple hundred degrees less, there is a problem. First thing I would do is run a compression test to verify base engine condition. And read the plug while it is out.
Re: Typical header tube temperature at idle? [Re: Hemi_Joel] #3071698
08/26/22 07:44 PM
08/26/22 07:44 PM
AndyF Offline
AndyF  Offline
140 is not firing, 500 degrees would be firing. Fast idle on the dyno is usually 900 degrees, 1300 to 1400 at WOT.
