Speedometer not working #3071410
08/25/22 05:00 PM
08/25/22 05:00 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
70 challenger and speedometer stopped working. If I take speedometer cable housing off transmission will I lose all of the transmission fluid ?
Re: Speedometer not working [Re: ct440rod] #3071414
08/25/22 05:19 PM
08/25/22 05:19 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
No, if you just remove the cable. If you take the speedo housing out, you will lose some.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Speedometer not working [Re: Prodart440] #3071426
08/25/22 06:30 PM
08/25/22 06:30 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
If you need to pull housing jack it up so fluid pools back and barely lose any.
Facts are stubborn things.
Re: Speedometer not working [Re: larrymopar360] #3071465
08/25/22 09:18 PM
08/25/22 09:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The back, IE: Jack up the rear end so the tailshaft fluid runs forward wink
beer
if your removing just the cable you shouldn't lose any. One can also then use a variable speed drill to check the cable and speedo itself. Also verify that the cable has not rounded out to opening in the gear smile
Re: Speedometer not working [Re: TJP] #3071475
08/25/22 09:24 PM
08/25/22 09:24 PM
MoreParts Offline
MoreParts  Offline
I did mine a few months ago and normal jacking and I didn't lose any. One word of advice from just doing it recently: lube that cable up really well with something like Kable-Ease, install the cluster side, then the tranny side.
Re: Speedometer not working [Re: TJP] #3071674
08/26/22 06:09 PM
08/26/22 06:09 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
beer
Yes, sorry I didn't word that very well.
