727 accumulator blocker rod - yea or nay for street car #3071071
08/24/22 01:09 PM
08/24/22 01:09 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
Currently building a 727 for 99% street use ('72 Road Runner, 451 low-deck stroker, 550hp).
Trans will have:
- Typical clutch upgrades
- Minor servo upgrades
- Typical valve body upgrades (TransGo TF-2 kit)
- 2500 stall converter
I'm good with a firm shift but don't want anything ridiculous or bone jarring at light throttle. Should I use the blocker rod or not? Thanks.
Re: 727 accumulator blocker rod - yea or nay for street car [Re: WarEagle1] #3071077
08/24/22 01:18 PM
08/24/22 01:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I put a blocker rod in my 2000 ram Cummins 47RE , ... shift kit was a variation of the TF-2 for OD trans... the shift was so harsh I took it out the next time I dropped the pan to change the filter.
Street car like you describe , I personally would not use one.
Re: 727 accumulator blocker rod - yea or nay for street car [Re: WarEagle1] #3071081
08/24/22 01:35 PM
08/24/22 01:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Trans will have:
Probably not. You could try it. Not like it isn't reversible. But based on your description, it will likely be too aggressive for you.
Re: 727 accumulator blocker rod - yea or nay for street car [Re: CMcAllister] #3071153
08/24/22 06:32 PM
08/24/22 06:32 PM
Mass
charge70 Offline
charge70  Offline
Mass
I was told to not use one on a street trans.No reason was given but it was from a person who knows 727's.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
