What front after market K member #3069887
08/20/22 01:52 PM
08/20/22 01:52 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
I Wanting buy a after market K-member and compete front suspension. upper and lower A-arms -shocks-rack- a whole kit. what brand would you get QA1 ? 1966 dodge coronet I am worry about front end travel. I run cal-tracs with mono leaf. But I want to take weight off the car. Was looking at this . https://www.summitracing.com/parts/qa1-52348-d350?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+Q&utm_term=4581252649396041&utm_content=GSAPI+5d4c9cc5a1c9b
Re: What front after market K member [Re: VernMotor] #3069900
08/20/22 02:15 PM
08/20/22 02:15 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
I run a QA1 front K member, heim joint UCA's, QA1 LCA's, heim jointed struts bars and Wilwoood hubs and front brakes, we still use torsion bars. IIRC this lot saved about 40lb's over all the stock stuff with cast iron sliding calipers. The QA1 K member was only about 2lbs lighter but the stock one was cut back and trimmed a long time ago. It still has good upward travel (6+inches) and I limit it at the moment to around 5".
Re: What front after market K member [Re: VernMotor] #3069911
08/20/22 02:57 PM
08/20/22 02:57 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
If this is a strip car, you'll want to talk to your provider about front suspension travel. Many do not have sufficient travel to transfer weight. My buddy had to go to the longer GM Calvert monos and bars to get his Dart to launch after swapping to coil overs up front. His car is sub 1.40 60 ft times. If you're slower than that, it may not make a difference.
Re: What front after market K member [Re: VernMotor] #3069917
08/20/22 03:29 PM
08/20/22 03:29 PM
AndyF Offline
AndyF  Offline
Is this a drag car? If so I'd just with a strut front suspension and get rid of a bunch of weight and extra complexity. A local chassis shop should be able to put together a strut front suspension for roughly the same price as a K frame setup.
Re: What front after market K member [Re: AndyF] #3069919
08/20/22 03:41 PM
08/20/22 03:41 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
This is a drag only car. Now I could drive on the street . But I don't . weight 3500 with me in it. runs 10.60s .I like to get it to run 10.50 . I run NSS on a index. 1.50 60 ft
Re: What front after market K member [Re: VernMotor] #3069922
08/20/22 04:07 PM
08/20/22 04:07 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
You might want to check out Hemi Denny. The torsion bar eliminator kit seems like a decent fix.
Re: What front after market K member [Re: Tig] #3069934
08/20/22 04:36 PM
08/20/22 04:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I lost 50lbs just going from 73 front disks to strange front disks.
I like the looks of the Hemidenny kits, like about all of those kits not a lot of front travel. Not a problem if your car is fast enough not to need much travel.
Andy, how much traves does your strut front have? Photo's?
Re: What front after market K member [Re: justinp61] #3069993
08/20/22 08:17 PM
08/20/22 08:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The aftermarket stuff saves very little. The geometry isn't as good as the stock stuff. The steering is definitely stiffer to turn. The steering radius is less. Trim the stock K frame. Make chrome moly strut rods and steering shaft. Use light brakes. The difference will be slight. Your wallet will be way heavier though.
Doug
Re: What front after market K member [Re: dvw] #3070004
08/20/22 08:45 PM
08/20/22 08:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Pics of the lightened K frame. No motor mount, trimmed the box mount and used moly tubing. Cut all the flanges off. Large oil pan access. The moly strut rods were made by cutting off the stock ends and reducing there diameter to fit snugly into 3/4" moly tube. Then welded back together. Steering shaft is also .090" moly tubing, The front fender braces and hood latch support are 3/8" moly tubing.
Doug
Re: What front after market K member [Re: dvw] #3070030
08/20/22 10:05 PM
08/20/22 10:05 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Save weight? Have Pam drive. LOL. I'll see myself out
Re: What front after market K member [Re: VernMotor] #3070036
08/20/22 10:40 PM
08/20/22 10:40 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Read the rules for NSS. Must keep steering box in stock location, must run torsion bars if factory equipped and no rack and pinion steering. whistling
Re: What front after market K member [Re: max_maniac] #3070062
08/21/22 04:46 AM
08/21/22 04:46 AM
AndyF Offline
AndyF  Offline
Yeah that throws a wrinkle into the discussion. If you have to be legal for NSS then you need to work within the rule book. I'd put a strut suspension in any serious drag car these days but if it isn't legal then it isn't legal.
Re: What front after market K member [Re: AndyF] #3070219
08/21/22 05:22 PM
08/21/22 05:22 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Always great topic everyone loves to disagree
I bought a Gert ( now qa1) for the 67 , it is a very nice piece and built well ..car drives like a dream
I bought a Alterkation for the wagon ,I'm sure it will be fine but had I know about HDK or Gerst then , I'd bought a different one
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: What front after market K member [Re: bigdad] #3070284
08/21/22 09:07 PM
08/21/22 09:07 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I am not sure if it fits your rules or if he makes them for a B body, but Tory Shellhamer's front end kit looks really nice. I have a couple of friends that are running one.
Off topic, Bigdad, do you know if any fibreglass panels are available for your early A body Valiant wagon???
Alan Jones
Re: What front after market K member [Re: LA360] #3070298
08/21/22 09:32 PM
08/21/22 09:32 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Ok well that about sum it up.. I can't do what I started out to. So I thinking I going with upper a-arms - strut rods - and glass hood . new lighter wheels. and lighten up the K-member. steering shaft.. I all ready have wilwood brakes
Re: What front after market K member [Re: LA360] #3070302
08/21/22 09:39 PM
08/21/22 09:39 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I do think Larry at Sled City does make early A body stuff
https://www.sledcityfiberglass.com/fiberglass/
Re: What front after market K member [Re: bigdad] #3070345
08/22/22 12:39 AM
08/22/22 12:39 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
GlassTek makes some early A body stuff too.
Re: What front after market K member [Re: VernMotor] #3070348
08/22/22 01:34 AM
08/22/22 01:34 AM
I bought and installed an Altercation replacement K kit from Oreily, I think that is the correct name, for one of my customers 1971 Challenger with power rack and pinion steering. He is having a 572 C.I. Hemi installed in it with a 727 and wants the power steering in it so his little wife can drive it also bow
It went in easy and fit well up
I would buy another one for myself for a project like that, RB or Hemiriod motor twocents
Re: What front after market K member [Re: VernMotor] #3070360
08/22/22 08:20 AM
08/22/22 08:20 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Vern the upper control arms are heavier than stocks. Struts are way lighter.
JAKES AUTOMOTIVE
Re: What front after market K member [Re: JAKE68] #3070361
08/22/22 08:27 AM
08/22/22 08:27 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
It will depend on who you run NSS with. Most have a rule pretty similar to this one.
SUSPENSION
FRONT SUSPENSION: Stock front suspension as factory-designed required. Aftermarket direct replacement suspension components including tubular A-arms permitted: However, overall design and function as factory produced must be retained.
I went through this too. I found like has already been posted, the control arms are heavier than stock. I ended up spending more time cutting and trimming lips, tabs and brackets to achieve the same result. There was a good bit of weight under the dash in my car.
What is the combo? Maybe a little left in converter or setup?
