Re: Rocker arm and Valve spring recommendations
[Re: mercman1]
#3070041
08/20/22 10:54 PM
08/20/22 10:54 PM
Posts: 43,233 Bend,OR USA
Cab_Burge
[Re: mercman1]
#3070370
08/22/22 09:10 AM
08/22/22 09:10 AM
Posts: 4,074 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I have a 520 wedge in my 69 GTX with the Trick Flow 270 heads. The heads came with springs that are rated to .700 lift before coil bind. My cam is a solid roller that was specked out with 1.6 rockers gives .696 theoretical lift. I am running the 1.5 Harland Sharp rockers that should give me .652 of theoretical lift. Both of these numbers are BEFORE the .020 lash. My question is can I run the 1.6 rockers with only .024 before coil bind? How much horse power is the .040 added lift worth? Motor has 12.5 compression, Intake duration is 266 and exhaust is 275 both @.050. Currently running the Victor 4500 intake and the car has gone 9.88 @133.50 with a 1.33 60 ft. Would a Indy 440-2 or 3 make more power? Thanks for your input. Who built your engine? Couldn't you reengage them on what can and can't be done because it seems to me it's a winner! ESPECIALLY since it appears you're using a stock block. Like you have stated, much of the info you've provided is probably more theoretical than actual including the DA and applicable RPMs. In general, when you start squeezing more out of a given good package you really need to know more precisely every detail. Generally you can run about .060" from C/B in your application.
[Re: rebel]
#3070971
08/24/22 05:27 AM
08/24/22 05:27 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
My street strip car has probably the next sized cam up from yours with 272/278@50, & 660 lift with 1.6 rocker arms. I use springs that are 230lb on the seat & have a spring rate of 555lbs. I'm installed at 1.95 & this engine revs out to 7000 rpm. I've just put the engine back in after I pulled it after 6 years of racing & the only things I changed were the valve locks & the roller lifters. And I only changed those parts coz I thort I should since its under a bit of stress. Your cam duration is the same as mine. What LSA is it ground on? mine is 110 degrees. Comp HXL lobes, so a hair over 0.700" lift with 1.6 rockers. Springs I am using are the PAC-1326 (663 lb/in rate, and 275 seat pressure). Likely stiffer springs than I need, but I got a deal on them from the head porter. Previous, used the PAC-1325 springs (644 lb/in rate, and 250 seat pressure.) Both rated for up to 0.800" lift when installed at 2.00"
[Re: 451Mopar]
#3070979
08/24/22 06:36 AM
08/24/22 06:36 AM
Posts: 4,647 aotearoa
rebel
aotearoa
My street strip car has probably the next sized cam up from yours with 272/278@50, & 660 lift with 1.6 rocker arms. I use springs that are 230lb on the seat & have a spring rate of 555lbs. I'm installed at 1.95 & this engine revs out to 7000 rpm. I've just put the engine back in after I pulled it after 6 years of racing & the only things I changed were the valve locks & the roller lifters. And I only changed those parts coz I thort I should since its under a bit of stress. Your cam duration is the same as mine. What LSA is it ground on? mine is 110 degrees. Comp HXL lobes, so a hair over 0.700" lift with 1.6 rockers. Springs I am using are the PAC-1326 (663 lb/in rate, and 275 seat pressure). Likely stiffer springs than I need, but I got a deal on them from the head porter. Previous, used the PAC-1325 springs (644 lb/in rate, and 250 seat pressure.) Both rated for up to 0.800" lift when installed at 2.00" Mine is also on 110 lobe sep.the 555 spring rate springs seem to survive well in my application. I bracket race in an 11.00 sec fixed dial in, street legal drag class on friday nights over summer, when the conditions are right & the fat lady is singing, my full factory trim e body will run 10.5 @127 on pump gas.
[Re: mercman1]
#3071728
08/26/22 10:55 PM
08/26/22 10:55 PM
Cab_Burge
