Shaving a friction #3069678
08/19/22 07:51 PM
08/19/22 07:51 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Can a friction be shaved and put against the the piston , then a a steel on top of it for setting clearance on the direct drum . I know that is not the correct way but can it be done .
Re: Shaving a friction [Re: 426lloyd] #3069695
08/19/22 08:26 PM
08/19/22 08:26 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Are you thinking of taking material off both sides or just one?
I've been into a few ZF transmission that use single sided frictions.
In most cases, a thin steel shim is against the endplate rather than the piston.
Angry white pureblood male
Re: Shaving a friction [Re: 426lloyd] #3069696
08/19/22 08:27 PM
08/19/22 08:27 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
we have done that in the past. learned that from a&a trans. we put them in the rear drum, between the drum and the part that the piston fits in. it takes up the slack to there is little to no end place in that drum. been doing it for years. also you need to trim the outside if you put it in there. but you can also use them to adjust clearance if you don't have a large selection of snap rings.
Re: Shaving a friction [Re: trw1982] #3069698
08/19/22 08:37 PM
08/19/22 08:37 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
I shaved both sides of the clutch friction dropped it in drum , put a steel on top of it then friction , steel , alternating and had perfect clearance , but not sure if it would cause a problem with the way I did it . Did a air check and it functions ok , has anyone else done this with good results
Re: Shaving a friction [Re: 426lloyd] #3070085
08/21/22 08:20 AM
08/21/22 08:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If the forward clutch is real loose you can put a extra steel between the pressure plate and the snap ring.
Doug
Re: Shaving a friction [Re: dvw] #3070116
08/21/22 10:46 AM
08/21/22 10:46 AM
moparx Offline
moparx  Offline
is this for a 727 or 904, or both ?
beer
Re: Shaving a friction [Re: moparx] #3070203
08/21/22 04:23 PM
08/21/22 04:23 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Its for s 727
