snout bar ??
#3069227
08/18/22 02:17 PM
08/18/22 02:17 PM
Posts: 19,485 north of coder
moparx
with the engine out of my charger, i had thought this would be a good time to add snout bars [from the firewall to the front of the K-member attaching rails]. if there is no bar or cage in the car, will this be another wasted time and effort idea i have come up with ? would there be any advantage at all with these bars ? i just thought it would be lots easier to do without the engine in the road. TIA for those out there WAY smarter than this old fart.
Re: snout bar ??
[Re: Wirenut]
#3069236
08/18/22 02:27 PM
08/18/22 02:27 PM
moparx
frame connectors are built, but not in yet. i am planning to tie the connectors to the rockers, and also installing torque box plates. i may, or may not put a simple roll bar in. Thank You for the reply.
Re: snout bar ??
[Re: moparx]
#3069251
08/18/22 03:06 PM
08/18/22 03:06 PM
Posts: 11,619 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Useless without a cage to tie them to through the firewall. The firewall is the flimsy part.
Re: snout bar ??
[Re: moparx]
#3069256
08/18/22 03:11 PM
08/18/22 03:11 PM
Posts: 1,774 Keymar, MD
DusterKid
Keymar, MD
Without a cage to tie the snout bar to I think it kinda defeats the purpose of the snout bar. Personally I wouldn't install a snout bar without a cage.
Re: snout bar ??
[Re: DusterKid]
#3069264
08/18/22 03:35 PM
08/18/22 03:35 PM
Posts: 4,688 On the parachute mount
n20mstr
IF you want the snout bars, remove the dash from the car. Plate each side (a pillar, dash level) Run a bar between those plates. Land your snout bars on that dash bar. WHen building the cage, it is ok to have the A pillar bars notched to fit the dash bar as it goes fully across the car. A lot of cars are built this way.
....BAD A$$ STREET CAR.....
Re: snout bar ??
[Re: n20mstr]
#3069532
08/19/22 12:11 PM
08/19/22 12:11 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
IF you want the snout bars, remove the dash from the car. Plate each side (a pillar, dash level) Run a bar between those plates. Land your snout bars on that dash bar. WHen building the cage, it is ok to have the A pillar bars notched to fit the dash bar as it goes fully across the car. A lot of cars are built this way. This is how we built mine also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: snout bar ??
[Re: Wirenut]
#3069591
08/19/22 03:16 PM
08/19/22 03:16 PM
6PKRTSE
Motor City
One thing I wish I would have done was to go outside the fender aprons for the snout bars under the fenders as it makes for a tight fit to get the rocker covers off of the Hemi with them within the engine bay.
Re: snout bar ??
[Re: Wirenut]
#3069592
08/19/22 03:17 PM
08/19/22 03:17 PM
moparx
thank you all ! the replies given has made my mind think clearer about the stresses incurring at the firewall without a cage bar backing up the snout bar. i had somewhat thought about this being a problem, but as the inner fenders are still there [and will remain] i wasn't sure what might happen. and as to further thoughts about adding a simple roll bar in the future, well, i have a ton of other things to do before or if that happens..........
Re: snout bar ??
[Re: moparx]
#3069623
08/19/22 05:05 PM
08/19/22 05:05 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Pretty sure these helped keep the front fenders springing into the doors after aborting a few big wheelstands. They are connected to the cage and plated to the fire wall. They're too big, the car is caged out in 1 3/4" CDS steam pipe and this contributes greatly to it's overall weight (4023lb at the line). One day I'll get a CM cage and pick up 2 tenths
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: snout bar ??
[Re: racerx]
#3069785
08/20/22 08:08 AM
08/20/22 08:08 AM
Tig
A shed in England
This is the way mine run, but further out to the front frame rails. Tig due you have interference with the tires running them this way when making turn (like off the track onto the return roads)? No Issues, but then again I haven't run anything wide on the front for years. We ran a 29" tall front on a 4" rim (it was nearer 30" tall unloaded) it caught the fender on full lock, we had to raise the front a little to clear it. The mount is the opposite the motor plate mount, TBH I cant see it adding any strength there. I had planned to weld a bracket to the snout bar to connect to the upper corner of the motor mount, that will have to wait till the next time though.
Re: snout bar ??
[Re: Tig]
#3069789
08/20/22 08:38 AM
08/20/22 08:38 AM
Posts: 4,072 Mo.
racerx
Mo.
This is the way mine run, but further out to the front frame rails. Tig due you have interference with the tires running them this way when making turn (like off the track onto the return roads)? No Issues, but then again I haven't run anything wide on the front for years. We ran a 29" tall front on a 4" rim (it was nearer 30" tall unloaded) it caught the fender on full lock, we had to raise the front a little to clear it. The mount is the opposite the motor plate mount, TBH I cant see it adding any strength there. I had planned to weld a bracket to the snout bar to connect to the upper corner of the motor mount, that will have to wait till the next time though. Thanks
Re: snout bar ??
[Re: racerx]
#3070001
08/20/22 08:39 PM
08/20/22 08:39 PM
Posts: 9,857 MI, usa
dvw
MI, usa
Mine attach under the fender. Then come thru the inner fender landing above the front K frame bolt. Tied to the front down bars of the cage, firewall, and shock tower. The down bars are attached to the lower windshield structure as well. No clearance issues or engine bay restriction. If i had thought about it I would've extended the motor plate to these bars as well. Had to cut a hole in the A pillar just in front of the upper door hinge to access the welds at the dash bar/snout/down bar junction. Then welded the cut out portion back in. Doug
Re: snout bar ??
[Re: dvw]
#3070044
08/20/22 10:57 PM
08/20/22 10:57 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
