Vacuum pump #3068980
08/17/22 08:20 PM
08/17/22 08:20 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
How much vacuum is ideal for street use 572 wedge. I now have around 5in. Would a smaller pulley on the pump be the way to go. The pulley on the pump now is 4 1/2” diameter. How much smaller pulley would kick it up to say 10”. Thanx for your time.
Re: Vacuum pump [Re: rickraw] #3069039
08/17/22 11:10 PM
08/17/22 11:10 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Wet sump? Dry sump? What pump and pulley ratio currently?
I would smoke test it to see if you have any leaks to start.
Re: Vacuum pump [Re: INTMD8] #3069053
08/18/22 02:47 AM
08/18/22 02:47 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I would have thort, if you had a good pump, you would have to set the relief to control your peak vacuum. I have 5" at idle & 10" at WOT with a Moroso 4 vane pump. As mentioned above, you might have a leak so maybe you need to test your system. I do know my pump is worth 0.12 to my ET. when it had a fail we looked at where the power went & found the pump drive was faulty. Once fixed the missing ET returned.
Re: Vacuum pump [Re: rebel] #3069070
08/18/22 07:19 AM
08/18/22 07:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Easy to make a fitting and use a $5 Harbor Freight regulator. Ring seal and the engine being sealed up will vary the result. Air up the motor with 5psi and spray with soapy water. If you have a leak it'll show. Mine makes about 10-12" with 5 at idle. GZ pump.
Doug
Re: Vacuum pump [Re: rickraw] #3069133
08/18/22 10:38 AM
08/18/22 10:38 AM
I had less than 5.0 inches on my 505 C.I. race motor in my S/P Cuda with an enhanced GZ vacuum pump in neutral at 1000 RPM up to 5000 RPM confused
The next race motor will have a four vane Moroso, or dry sump oil system. I'm hoping for 12.0+ inches revved up above 5000 RPM luck
Re: Vacuum pump [Re: dvw] #3069145
08/18/22 10:50 AM
08/18/22 10:50 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Same here.
I can regulate it for 15 but adjusted to 10.
Re: Vacuum pump [Re: rickraw] #3069173
08/18/22 12:02 PM
08/18/22 12:02 PM
an8sec70cuda Offline
I have a 4 vane Moroso on my 575" hemi that pulls about 10" at WOT.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Vacuum pump [Re: an8sec70cuda] #3069291
08/18/22 04:40 PM
08/18/22 04:40 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
Ok thanx guys. I just checked it at idle, had about 5. Didn’t check it with any rpm, that will be next. I’ll post some pics of my new ride someday. Here’s the engine.
Re: Vacuum pump [Re: rickraw] #3069316
08/18/22 05:46 PM
08/18/22 05:46 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Ran a vacuum pump for years on the street. Not sure why anyone would want to regulate the vacuum it makes, usually any extra just helps ring seal along with other things. bang for the buck, its hard to beat a maroso vacuum pump, but there is other good options as well.
Re: Vacuum pump [Re: rickraw] #3069322
08/18/22 06:14 PM
08/18/22 06:14 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
When people say what vac they pulling , they should say what block material . Alum or cast iron will make a difference
....BAD A$$ STREET CAR.....
Re: Vacuum pump [Re: an8sec70cuda] #3069487
08/19/22 10:43 AM
08/19/22 10:43 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Same here on my 528" Hemi.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Vacuum pump [Re: 6PKRTSE] #3069530
08/19/22 12:05 PM
08/19/22 12:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have not had a BB of mine pull less that 15" of vacuum at WOT in YEARS,if it does not its leaking somewhere. Generally all 4 vane enhanced or Star pumps(seem to be a tad better) These are all aluminum block deals and wet sumps. The Stratus pulled 19" with a dry sump and vac pump.the one iron block we did when my son first started racing the dragster as his "training wheels" was a 446" stock block that we pulled 11" at WOT. FWIW the heads up car has seen 19" as a wet sump with a moroso 4 vane on an aluminum block driven by a serpentine belt. But it is a brand X deal.
Re: Vacuum pump [Re: rickraw] #3070373
08/22/22 09:19 AM
08/22/22 09:19 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Again it'll pull more vac than 5 at higher engine rpm. You have to do the math with pulley ratios. Be aware that each type of pump has its RPM limit.
Re: Vacuum pump [Re: HardcoreB] #3070533
08/22/22 05:13 PM
08/22/22 05:13 PM
Ambridge, Pa.
rickraw Offline OP
rickraw  Offline OP
Ambridge, Pa.
It’s a gz. I did raise the rpm roughly to 4000, pulled 10” so it’s working fine. Never had a vac pump, just getting so input. Thanx everyone.
Re: Vacuum pump [Re: rickraw] #3070540
08/22/22 05:24 PM
08/22/22 05:24 PM
New York
blakeadam Offline
blakeadam  Offline
New York
Re: Vacuum pump [Re: Cab_Burge] #3071578
08/26/22 11:20 AM
08/26/22 11:20 AM
Fort Scott, KS
67CudaRacer Offline
67CudaRacer  Offline
Fort Scott, KS
We have a new 4 vane enhanced Moroso with about 4 dyno pulls on it for sale.
