Cuda Bottom Color #3068943
08/17/22 06:22 PM
08/17/22 06:22 PM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
I have a 70 Cuda Vert FC7 built at Hamtramck. It has remanace signs of having the gray, red oxide and black.
Any ideas of what it shoud be?
NS1AAR
Re: Cuda Bottom Color [Re: ns1aar] #3069104
08/18/22 09:29 AM
08/18/22 09:29 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Which color is closet to the bare metal, as it been restored in the past ?
Re: Cuda Bottom Color [Re: JohnRR] #3069161
08/18/22 11:34 AM
08/18/22 11:34 AM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
Hasn't been restored before. Not undercoated no gray on the bottom mostly dirt and something that might have been faded black. I couldn't figure if it was really cheap paint or a mix of oil and dirt. It had the gray dip on the inside with red oxide on top of that and then color
The car sat in a Texas wrecking yard for awhile.
NS1AAR
Re: Cuda Bottom Color [Re: ns1aar] #3069351
08/18/22 08:14 PM
08/18/22 08:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Bottom body dip color should also match whatever is found inside behind the door panels etc. Used car dealer, or a past owner, may have sprayed something else on the bottom at some point? I would use whatever shade of grey or black you find inside the car.
Re: Cuda Bottom Color [Re: ns1aar] #3069360
08/18/22 08:54 PM
08/18/22 08:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Grey bottom, Red Oxide on top. Troy's T/A looked like faint rust on top, but it was the worn thin faded paint showing the red oxide underneath. Built at Hamtramck in the T/A-AAR period like your AAR.
Seems to really show on Silver cars for some reason
Black you are seeing may be overspray from wheel wells, truck black out, pinch weld black out (sometimes sprayed).
LA cars seems to have black primer/base on underneath.
Re: Cuda Bottom Color [Re: autoxcuda] #3069399
08/18/22 11:46 PM
08/18/22 11:46 PM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
That works the Vert had the same red on the top
NS1AAR
