Converting from Lean Burn to standard ignition
#3068940
08/17/22 06:05 PM
08/17/22 06:05 PM
Posts: 5,797 minnarusta
TX9H6E4CUDA
minnarusta
I have a 1980 Gran Fury squad car with a 360 4bbl Lean Burn. I have a electronic ignition conversion kit and non lean Burn thermoquad. So my question is do I use the wiring for the computer or do I just start from scratch? What is the best way to wire up a electronic conversion from Lean Burn.
Thank you for any help given
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Converting from Lean Burn to standard ignition
[Re: TX9H6E4CUDA]
#3069452
08/19/22 09:34 AM
08/19/22 09:34 AM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
On my 79 Cordoba, my goal was to keep it original looking. I had a spare Lean Burn box, gutted it and cut the bottom to add clearance for the orange box connector. I cut off the old Lean Burn ECU plug off the circuit board and soldered to the pigtail for the electronic ignition. All the wiring needed is in the factory wire to the lean burn. I was concerned about heat, but I think the high volume of air moving around keeps the orange box cool enough. This was done 20 years ago and I used to use the car pretty much every day back then. In theory I could swap back in another lean burn module and old distributor and go back to stock, not that I want to.
[Re: njmopar]
#3069453
08/19/22 09:43 AM
08/19/22 09:43 AM
Posts: 10,647 S.E.Ohio
Magnumguy
S.E.Ohio
Not an absolute, but you get the full affect if you change the carb to a pre-leanburn version. The vacuum signal is opposite from the std. ignition w/vacuum advance.
I have one car I kept the leanburn hooked up, and ran a dizzy with VA and changed the carb ( as the car had sat for years and the carb was varnished up ). What a difference.
I have actually had good experiences with lean burns. I've owned 20+ Magnums and a few Dobas over the years, and have not had much trouble. Some of the Magnums I've bought have had the change done already. I certainly don't change it back.
[Re: Magnumguy]
#3069492
08/19/22 10:55 AM
08/19/22 10:55 AM
Posts: 2,922 Calgary, Alberta Canada
a12rag
I have actually had good experiences with lean burns. I've owned 20+ Magnums and a few Dobas over the years, and have not had much trouble. Most of the Magnums I've bought have had the change done already. I certainly don't change it back. Yes, the lean burn carbs are built to be LEAN ! . . . Changed the lean burn off the 77 New Yorker I had gotten, and used a TQ I had rebuilt, that was from a 74 440 . . . what a difference for sure !!
[Re: TX9H6E4CUDA]
#3069640
08/19/22 06:05 PM
08/19/22 06:05 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thank you for any help given When they work, they work pretty well. When they go bad, chug, chug, chug. I had one go bad. Pic of the 80 A38 Gran Fury PLEASE Love those E58's!
Facts are stubborn things.
[Re: TX9H6E4CUDA]
#3069741
08/19/22 10:45 PM
08/19/22 10:45 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Thank you for any help given I did a Pertronix II swap using a single point vac adv Chrysler dist / Pertronix II kit 91381A and Pertronix Flame Thrower coil as the starting base, changed the intake out for an Edelbrock 4 bbl manifold/Holley 600 CFM on a 1980 5th Ave, just trash all the lean burn junk, no ballast resistor required, the Pertronix is very straight forward, you just need the hot ignition (run) lead..... the rest can hit the trash can
[Re: Moparite]
#3070125
08/21/22 11:35 AM
08/21/22 11:35 AM
Posts: 6,320 nowhere
Sniper
nowhere
