Cam Core Dia for Big Lift #3068551
08/16/22 03:58 PM
08/16/22 03:58 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Q: What cam bore diameter can us Mopar folks run in a Calaise block? What is the next step up from stock, and when do you need one? How much cost to a cam does it add?
Re: Cam Core Dia for Big Lift [Re: Dragula] #3068626
08/16/22 08:33 PM
08/16/22 08:33 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Based on comments made in previous posts, 60mm cores for Hemi engines are pretty common. The Fuel guys run them.
What do you consider to be "big" in regards to lobe lift?
Alan Jones
Re: Cam Core Dia for Big Lift [Re: LA360] #3068661
08/16/22 09:55 PM
08/16/22 09:55 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I have an older SS block that is machined for a 2.500" cam tunnel bore, Ford 2.125" cam journals. Ford Performance sells the five roller bearings at a good price. The stock front journal is about 50mm, so 55mm or 60mm are the next steps up in roller bearings after the BBF journal size. I'd check on availability and prices on cams before machining the block.
Floyd Lippencott IV
Re: Cam Core Dia for Big Lift [Re: Dragula] #3068707
08/17/22 12:13 AM
08/17/22 12:13 AM
I've read both 55MM and 60 MM cam cores and bearings being use for all out BB after market race blocks scope up
As already ask how much lift do you want to use? What rocker arm ratio?
Lots of way to make things happen your way work up
Re: Cam Core Dia for Big Lift [Re: Cab_Burge] #3068749
08/17/22 08:07 AM
08/17/22 08:07 AM
Dragula Offline OP
Dragula  Offline OP
I am just curious....I am at .750 lift now on the street/strip car, and wondering how the cam & bearings are holding up. Lots of spring pressure already, and I know guys are running .800" lift on the street these days. The only way I can imagine that is with a thicker cam core...I may have answered my own question there, but I am curious what others have done. I want to make this car somthing I could take on Drag Week. So when I look at cams next time, I want to be able to figure out if I need to go to a 55mm or 60mm core or maybe stay where I am at.
Re: Cam Core Dia for Big Lift [Re: Dragula] #3068754
08/17/22 08:24 AM
08/17/22 08:24 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A coated cam bearing, and using a heavier weight oil will be your best bet for a Drag Week combo. Oil temp, and valve spring cooling is the key to surviving Drag Week. Also using bushed components, instead of needle bearings is another DW must use type deal. making a car work on the track is completely different than one that needs to drive 250-300 miles per day. The drives take out more cars, then the track.
69 GTX 68 Road Runner
Re: Cam Core Dia for Big Lift [Re: JERICOGTX] #3068756
08/17/22 08:32 AM
08/17/22 08:32 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I like the Durabond coated cam bearings.
I was advised not to exceed .500 lobe lift and 900psi open spring pressure on a stock journal size cam core.
Something about the base circle getting small IIRC?
What are the first sogns of camshaft flex? Would you see it in the bearings first?
Re: Cam Core Dia for Big Lift [Re: Jeremiah] #3068796
08/17/22 10:20 AM
08/17/22 10:20 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run a .730ish lift solid roller with a heavy spring on my small block. A recent inspection after 5 years revealed my cam bearings looked horrible. 3 drag weeks, 150-200 passes, and 5000-7000 miles maybe? I just went back with standard but will likely have this engine apart again before 5 years.
68 Barracuda Formula S 340
Re: Cam Core Dia for Big Lift [Re: Bad340fish] #3068804
08/17/22 10:28 AM
08/17/22 10:28 AM
Dragula Offline OP
Dragula  Offline OP
Yeah, that is what I am afraid of....No good way to inspect them either....I put 2000 miles on mine last summer, and zero so far this year, but...
Re: Cam Core Dia for Big Lift [Re: Dragula] #3068857
08/17/22 12:23 PM
08/17/22 12:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Whats big lift? As mentioned 55 and 60MM are pretty common. If it is a wedge much harder to come by at times. Hemi/Predator stuff much asier to find as the blown alky guys use the bigger cores. IMO most any cam selection over .800 will greatly benefit from a larger than stock core, there is a surprising amount of flex with BIG lift cams and the normal big lift springs they require. Getting the block machined would be your next issues. But Weston Machine can handle it and do it right and he's in NJ so not that far away for you.
Re: Cam Core Dia for Big Lift [Re: Al_Alguire] #3068871
08/17/22 01:28 PM
08/17/22 01:28 PM
Dragula Offline OP
Dragula  Offline OP
I figured its probably about .800 valve lift. like you're saying...If I redo this engine this winter, I was wondering if i should open up the bores and get a nice big bore, tight lash cam that is Drag Week friendly and yet makes the HP...Not sure if that is possible....But one of the reasons you don't see these engines on Drag Week is the valve train....Might be ok at car cruises, and some weekend flogging, but not 1400 miles and then more flogging...Never gonna happen.
I should just put a Hellcrate in the damn car and start enjoying it...one of these years.
Re: Cam Core Dia for Big Lift [Re: Bad340fish] #3068879
08/17/22 02:08 PM
08/17/22 02:08 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What spring pressures are you running? 260-280 on the base and 700-740 on the nose (open)?
Re: Cam Core Dia for Big Lift [Re: Jeremiah] #3068883
08/17/22 02:16 PM
08/17/22 02:16 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Shimmed like I have them they are probably 250 on the seat, not sure what open is but I doubt it is as high as you mention. I lose a lot of lift due to the 59* lifter angle and the offset intake pushrod so they are shimmed up a fair amount to be .050-.060 from coil bind. These springs did two drag weeks and still checked out within spec on seat pressure, did a third with them and retired them for a larger cam and the comp 955 spring that is a little heavier.
Re: Cam Core Dia for Big Lift [Re: Al_Alguire] #3069317
08/18/22 05:52 PM
08/18/22 05:52 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
100% Al, couldn't agree more. FWIW I just finished a block that i had 55mm cam core done with needle bearings. I had bullet make me a 55mm cam and we used a jessel key way lifter that uses a bushing instead of needle bearings. after it was machine, there was a couple places that had less the .200 of material left.
Re: Cam Core Dia for Big Lift [Re: cuda499] #3069339
08/18/22 07:11 PM
08/18/22 07:11 PM
gregsdart Offline
gregsdart  Offline
I currently run a stock cam core, .868 gross lift, .510 lobe lift, stainless valves, 7500 rpm max. Flex when checking lash showed an increase of . 005 to . 006 in lash around the base circle from flex and compression. I would love to see a spintron video of what is going on at 7500 rpm! A move to a bigger cam core, higher rocker ratios and Ti valves is all in the interest of a better race valvetrain.
Re: Cam Core Dia for Big Lift [Re: gregsdart] #3069484
08/19/22 10:41 AM
08/19/22 10:41 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a 55MM camshaft with roller cam bearings and over .800 lift in my street/strip Hemi.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cam Core Dia for Big Lift [Re: 6PKRTSE] #3069499
08/19/22 11:11 AM
08/19/22 11:11 AM
Dragula Offline OP
Dragula  Offline OP
How many street miles on it? Are you ever afraid of the roller bearings finding their way into somthing else?
Re: Cam Core Dia for Big Lift [Re: gregsdart] #3069531
08/19/22 12:11 PM
08/19/22 12:11 PM
Are your rocker arms on a single shaft or are they a paired shaft set up?
I'm thinking single shafts systems flex, especially on motors with high (250Lb+ on the seat with 700+ lbs. open) valve spring pressures work scope
Re: Cam Core Dia for Big Lift [Re: Dragula] #3069535
08/19/22 12:15 PM
08/19/22 12:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
How ma
Over 5 years and thousands of miles. So far so good.
Re: Cam Core Dia for Big Lift [Re: 6PKRTSE] #3069539
08/19/22 12:20 PM
08/19/22 12:20 PM
Your example is perfect showing not all parts respond and perform the same work
What brand did you buy and use?
Did you have the rear cam bearing enlarge also for the 55MM or leave it stock and use a stock Babbit type rear stock bearing their?
