To the People who use mechanical fans #3067796
08/14/22 10:37 AM
08/14/22 10:37 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I wasn't going to post this, but I thought it might someone else out there.
I prefer electric over mechanical, and this weekend is probably the best case I have...to stay with Electric fans.
Well this was Gold Cup weekend at Empire...or Nostalgia Racing...plus TNT on Friday....
My cars are down for lack of money and parts primarily, so I have been running my engine builders 69 Dart...
Now the Dart is a street car, we run it in DOT street classes, and its mild, but not a slouch. It has 10x29 DOT "tires" on it, and gets down the 1/4 in 10.9 seconds in full street trim.
We ran it last week in 1/8th mile in the Mopar Day street class at Lancaster and went out 2nd round cause I left it in 2nd gear for the launch and went 7.48 instead of a 6.94 and was off mile dial pretty far. Yet mph was the same...But we had the fastest street car in the class and best reaction times and I was going rounds and having fun until I goofed up.. And that was against some of the fastest Hellcats around. Had a blast racing with all those guys.
Then this week came around, and its my birthday and GF didn't plan anything and buddies all said lets go racing...So I tow the car all the way to work so I can leave right from there for Empire. Get to the track after work about 1.5hrs later and unload and proceed to take the exhaust off. Nostalgia racing does not allow exhaust. So its a full exhaust with X-pipe...came off real easy and I hopped in the car to make a TT.....Was one of the first cars up to the line.
Well, I do my burn out, make sure I am in 1st gear this time and wait for the lights to come down. Well, I think I got 60ft before all hell broke loose, literally....The car under full throttle went hard right, I do not know how I missed the wall..Then it went hard left and I corrected again, and now it was tripodding trying to roll over and was on three wheels, I corrected again and it did it one more time the other direction on three wheels....Used up almost the whole track and idled down to the first turn off all shook up. It was taking me a minute to process everything.
Get pulled over, and the track guy is barking orders at me thru the windshield. I told him I needed a second...I finally get out realizing I saved the car big time, and open the hood. Mechanical fan hit the rad and was pissing antifreeze out...Yep antifreeze...I got a shellacking from the track owner about that when he came down to chew me out....Its a street car I told him, and I borrowed it.
Morel of the story, if your going to race every week, better off with electric fans. eventually, that mechanical fan going to come apart or flex too much, and you gonna have a problem...All the witness's say they could believe I saved it. I cannot find any vids from that night, but I will keep looking.
Re: To the People who use mechanical fans [Re: Dragula] #3067805
08/14/22 11:16 AM
08/14/22 11:16 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I was using my wifes Barracuda, it had a supplementary electric fan on the front of the rad which wasn't wired up as it really didn't need it. During a particularly enthusiastic burn out the mechanical fan drew enough air through it to make it explode and take the rad out blush Just another word of warning grin
Re: To the People who use mechanical fans [Re: Tig] #3067837
08/14/22 01:04 PM
08/14/22 01:04 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Why did you drive all the way down track, let off and pull to the side! ‘Well the wheel came off but I’m driving it out!’
Re: To the People who use mechanical fans [Re: cudaman1969] #3067845
08/14/22 01:31 PM
08/14/22 01:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Only times I've had a fan in the radiator was due to failed engine/trans mounts on a Charger, and an old Ford PU whose water pump came apart.
That's two occasions since 1966...
That said, on the faster stuff - say, into the 10s, or a road course car - I typically run an electric fan for a variety of reasons.
Why would there be antifreeze in the car at a drag strip ? That's forbidden for obvious reasons, and should have been caught and dealt with beforehand.
I'm also a believer that when a drag car gets out of shape, back out of it before the day gets worse...for the car, or you, or the guy next to you, or the guys in line behind you.
Re: To the People who use mechanical fans [Re: Dragula] #3067853
08/14/22 02:07 PM
08/14/22 02:07 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Good job on the save, but next time do all the other racers at the track a favor and when something like that happens and pull over instead of going the rest of the way down the track.
Re: To the People who use mechanical fans [Re: DusterKid] #3067869
08/14/22 02:41 PM
08/14/22 02:41 PM
Dragula Offline OP
Dragula  Offline OP
You know, I thought about pulling over after the fact, but they would have had 3 gallons of antifreeze rolling down the track from wherever I stopped it, plus it still had to get off the track somehow as that thing pissed coolant all the way back to my pits and then in the trailer on the way home......And I was already more than halfway down by the time I got it under control. So if it makes all you happy, which I know it won't...I will stop right there and get out of the car....Instead it left 3 gallons up on the edge of the return road and a small stream down the track.
So no coolant will go in it this week....Again wasn't my car, and had no idea street cars aren't allowed coolant...Do all the late models remove their coolant?
Re: To the People who use mechanical fans [Re: Dragula] #3067903
08/14/22 04:24 PM
08/14/22 04:24 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Good save. It’s easy to armchair, but in the heat of the moment, when you’re sawing the wheel, it’s a whole different ball game.
Re: To the People who use mechanical fans [Re: Dragula] #3067975
08/14/22 07:37 PM
08/14/22 07:37 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'm glad you saved it to race another day.
My Dart is a street/strip deal, pump gas small block that runs 6.40 in street trim. It also has a mechanical fan, about twice a year I go over the car from front to back and check everything. The fan and w/p are part of the checkup. Everything wears out eventually.
Re: To the People who use mechanical fans [Re: Leigh] #3067976
08/14/22 07:39 PM
08/14/22 07:39 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Thanks for sharing. I just got back from the Mopar Nats and was complating going electric.. Glad you saved yourself and the car
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: To the People who use mechanical fans [Re: 67mprfan] #3067978
08/14/22 07:58 PM
08/14/22 07:58 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Locally a guy was using a stock pulley and it broke and he drover over it at about 100 mph , went for a bad ride .. car was destroyed , he got some severe bruises from crotch belt
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: To the People who use mechanical fans [Re: bigdad] #3068039
08/15/22 01:05 AM
08/15/22 01:05 AM
New York, USA
Chargerfan68 Offline
New York, USA
About 3 years ago, my stock crank pulley exploded on the top end and My slick just caught it on the outer edge. Boy was I lucky nothing bad happened. I do run tubes and luckily it sliced the slick but not all the way through. That could have been real ugly.
Re: To the People who use mechanical fans [Re: Chargerfan68] #3068069
08/15/22 09:10 AM
08/15/22 09:10 AM
fredericksburg,va
fredericksburg,va
One in a million freak accidents, i won’t worry about them.
Re: To the People who use mechanical fans [Re: Leigh] #3068090
08/15/22 09:35 AM
08/15/22 09:35 AM
Dragula Offline OP
Dragula  Offline OP
Thanks. I was so shook up....Never had a car go so squirrely at that speed that I had to wrestle it so much....I wish I could find a vid of it. They say it was on three wheels twice...I am very glad I saved the car, as it was not mine.
Re: To the People who use mechanical fans [Re: Dragula] #3068247
08/15/22 06:41 PM
08/15/22 06:41 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Why do modern cars use electric fans?
Quieter
Mileage
Smaller grill opening (lower drag)
An electric pusher fan (in front of the core) is... a mistake.
Boffin Emeritus
Re: To the People who use mechanical fans [Re: Dragula] #3068252
08/15/22 07:20 PM
08/15/22 07:20 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
What kind of mechanical fan was it?
Re: To the People who use mechanical fans [Re: polyspheric] #3068331
08/15/22 10:43 PM
08/15/22 10:43 PM
fredericksburg,va
fredericksburg,va
Quieter
Mileage
You forgot, no room for an engine fan
Re: To the People who use mechanical fans [Re: cudaman1969] #3068348
08/15/22 11:36 PM
08/15/22 11:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
...and so many are mounted sideways...
Re: To the People who use mechanical fans [Re: polyspheric] #3068373
08/16/22 06:56 AM
08/16/22 06:56 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Definitely not the most efficient way of doing it but since we didn't have the space we had to, it works off two temp sensors and brings the 2nd in when needed. To my surprise it's been fine for 15+ years up
Re: To the People who use mechanical fans [Re: Tig] #3068428
08/16/22 10:47 AM
08/16/22 10:47 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
We've been using a clutch fan for the last 7+ years on the '63.
Lots of street miles and strip passes with zero issues. We do run the Moroso underdrive pulley.
'63 Dodge 330
11.19 @ 121 mph
Re: To the People who use mechanical fans [Re: Dragula] #3068455
08/16/22 12:04 PM
08/16/22 12:04 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nope.
The normal procedure is wait until there is a big problem of some kind, then scream at whoever has coolant that they should not have coolant.
And then after the big problem is over with... continue not checking any vehicles to see if they have coolant, but continue being all fastidious about seat belt dates and things like that.
Rich H.
Esse Quam Videri
