Edelbrock Carb Needle & Seat Sticking? #306728
05/03/09 06:48 PM
05/03/09 06:48 PM
fury4speed Offline OP
Edelbrock #1413 800 CFM Carburetor , car will start up and run fine but if it sits for a month or two , actually 2 month's exactly the car will not start , disconnect the fuel line after the fuel pump and gas is squirting out everywhere , take the fuel line off from the carburetor and there is gas , take the top of the carburetor off and compleatly dry , so I assume the needles are sticking not allowing gas to enter the carburetor , my question is why? the carburetor was brand new when I bought it year and a half ago , I bought a new edelbrock needle and seat , one needle is black and one is red (the rubber tip part) is one a new style? as always thanks in advance for your help.
Re: Edelbrock Carb Needle & Seat Sticking? [Re: fury4speed] #306729
05/03/09 07:08 PM
05/03/09 07:08 PM
The gas in the bowl is evaporating out in that period of time. try priming the bowl vents & with a few accel pump squirts it should kick right off.
Re: Edelbrock Carb Needle & Seat Sticking? [Re: RapidRobert] #306730
05/03/09 07:13 PM
05/03/09 07:13 PM
I even put gas in the primary side of the carburetor , it will run for a second or two then stop , and I am pumping the carburetor also when I am cranking it over , I have never had this problem with any other carburetor.
Re: Edelbrock Carb Needle & Seat Sticking? [Re: fury4speed] #306731
05/03/09 07:19 PM
05/03/09 07:19 PM
if you fill the bowl up enough to where the AP squirts will it keep running
Re: Edelbrock Carb Needle & Seat Sticking? [Re: RapidRobert] #306732
05/03/09 11:07 PM
05/03/09 11:07 PM
What is the best way to fill the bowl with gas?
Re: Edelbrock Carb Needle & Seat Sticking? [Re: fury4speed] #306733
05/03/09 11:25 PM
05/03/09 11:25 PM
minnesota, USA
greenfire Offline
greenfire  Offline
minnesota, USA
i would just start it up and let it run for a bit every 2 weeks then you wont have to worry bout the floats sticking
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: Edelbrock Carb Needle & Seat Sticking? [Re: greenfire] #306734
05/04/09 08:00 AM
05/04/09 08:00 AM
scratchnfotraction Offline
crappy gas now days evaps fast and will leave the carb full of a brown/rust colored grainualr crap that will cause the needles to stick
chewed mine up and cloged the airbleeds also
may need a good cleaning while you at it
blow all the passages out good and change needles and seats
my needles and seat had a nasty tarnish on all the brass parts along with the grit,a good soaking and air hose and it went right back to being trouble free
prime it or start it more often,IMO
good luck
Re: Edelbrock Carb Needle & Seat Sticking? [Re: fury4speed] #306735
05/04/09 08:23 AM
05/04/09 08:23 AM
Dribble some gas onto the bowl vent which looks like the business end of a hypodermic needle sticking straight up. Put enough in(~an ounce or so) to where you move the throttle & get a good gas squirt from the AP EDIT just use a small enough funnel or turkey baster etc so the gas goes into the vent & not washing down the cyls & get it full(not too much not too little)to where the AP makes a full stream
