Re: brake hose source
[Re: 72duster318]
#306687
05/03/09 10:02 PM
05/03/09 10:02 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I used to run SS from Russell on everything. They were the same price as rubber so why not? You did have to know that the drum brake setup had to be ordered even if you are running discs, if you get a disc set it is for I think Wilwoods so it won't work with stock type stuff.
I will add it has been a few years since I bought any,so that might have all changed.
I want my fair share
