^9 Plymouth B-body hood measurement needed #3066651
08/09/22 07:53 PM
08/09/22 07:53 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Can someone get me a measurement from a '69 Plymouth B-body hood please.
I need the measurement from the right side (standing in front of the hood) to the center of this hood latch bolt hole.
Re: ^9 Plymouth B-body hood measurement needed [Re: Stanton] #3066665
08/09/22 08:45 PM
08/09/22 08:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
28" - I measured from the outside of the flange (easier to hook the tape measure) to the center of the bolt.
That's the driver side flange, which I think is what you meant by "right, facing the hood".
Re: ^9 Plymouth B-body hood measurement needed [Re: topside] #3066709
08/09/22 11:35 PM
08/09/22 11:35 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Its a "glass " hood so it has a flat flange all the way along the side. We get 27-1/2" to the center of that bolt and its not lining up with the latch.
Re: ^9 Plymouth B-body hood measurement needed [Re: Stanton] #3066776
08/10/22 10:29 AM
08/10/22 10:29 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
So, 1/2" + the flange difference, that's off by 5/8" - 3/4".
Probably easier to modify the latch bar than correct the nutsert locations.
Relocating the latch in the upper grille panel toward the driver's side might create a lot of grief, but worth looking at.
I don't think using a '68 latch bar will work, as the fore/aft location differs, but maybe worth a look as well.
Only other alternative I can think of right now - maybe I need more coffee - is to use the secondary latch & hood pins.
Re: ^9 Plymouth B-body hood measurement needed [Re: topside] #3066932
08/10/22 09:08 PM
08/10/22 09:08 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I'm thinking I might just modify the bar or make a new one. I have a spare that I can sacrifice.
By the way, thanks for the info.
Bought the hood from a member here. Of course he didn't mention any problem nor was the hardware included. This is a VFN hood ... wonder if anyone else has the same issue
Re: ^9 Plymouth B-body hood measurement needed [Re: Stanton] #3066935
08/10/22 09:19 PM
08/10/22 09:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Some 'glass stuff is pretty far off, and you don't really know until you bolt it on.
I've seen the hinge bolt nutsert off by 1/2", and the whole hood being offset to the left by 3/8" because the halves were incorrectly positioned.
Some are bowed badly as well.
I think modifying or fabbing the bar is the most elegant solution.
