cuda jack #3052326
06/22/22 08:32 AM
06/22/22 08:32 AM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
What style jack is correct for a 1971 Barracuda conv. built June 14,1971.
Have both styles and a 101 hook . TYIA
Re: cuda jack [Re: GVH] #3052367
06/22/22 11:31 AM
06/22/22 11:31 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Not sure which jack is correct, but the 101 hook is for rubber bumpers. 100 is for steel bumpers.
Re: cuda jack [Re: 318 Stroker] #3052417
06/22/22 01:50 PM
06/22/22 01:50 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I don't recall if I've ever seen a discussion breaking down proper timing for hollow versus T shaped mast jacks. I wonder if it might be a situation where they used 2 different suppliers and both were used concurrently?
Another jack related item I've never even seen discussed is that some components are occasionally seen painted dark green instead of gray. I've seen the hook and maybe the base painted green on some '71s. Including my friends June built '71 Challenger convertible that he has owned since '73 so very likely the original jack.
Re: cuda jack [Re: 318 Stroker] #3064373
08/01/22 02:52 PM
08/01/22 02:52 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Tube jack is correct, also look for date code on the jack mechanism rivet
Re: cuda jack [Re: GVH] #3064550
08/02/22 05:33 AM
08/02/22 05:33 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: cuda jack [Re: DAYCLONA] #3064606
08/02/22 11:09 AM
08/02/22 11:09 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
June is a later build. When did they change to the slotted bumpers. It was sometime in late 71 production.
Re: cuda jack [Re: burdar] #3066421
08/09/22 12:38 AM
08/09/22 12:38 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The slotted Bumpers came out in June of 1971 on a Challenger. The slotted Jack I believe is a 1972 use. Barracudas did not come out at the same time but I do not know a date for this. My Challenger has front and rear slotted bumpers and is an early June built car. It some times is hard to come up with a date because Challengers were running over a week late at this time so a Challenger with a example May 24th SPD would of been built in June but a Barracuda with the same SPD May 24th was built in May..
1971 HEMI E BODY REGISTRY
