Re: 29" slick on a Duster
[Re: topside]
#3066322
08/08/22 07:20 PM
08/08/22 07:20 PM
Posts: 1,892 Spahn Ranch
RMCHRGR
Spahn Ranch
Topside - would trimming or bending the wheel opening lip flat at the bottom front be of any benefit? The outside of the car is not getting painted otherwise I'd think about doing what you suggested.
'71 Duster '72 Challenger '17 Ram 1500
[Re: AndyF]
#3066356
08/08/22 08:32 PM
08/08/22 08:32 PM
Posts: 5,618 long island NY
Ari440
long island NY
I had to roll the lip over
Cut the front lower lip 1/2
Stock leaf spring location Caltrac setup
10 inch rim 5 inch back space
29.5 10.5 15 M/T slicks
1.39 9.85 - 137 mph
[Re: Ari440]
#3066401
08/08/22 10:28 PM
08/08/22 10:28 PM
RMCHRGR
Spahn Ranch
Anybody have up close pics of the trimming? I've looked at lots of pics around the internet but it's tough to see what it actually looks like? Looks like I'd have to make the cut where the red outline is.
[Re: DusterKid]
#3066466
08/09/22 08:42 AM
08/09/22 08:42 AM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
If it were me, rather than cutting the car, I would stick with a 28 tire. You are currently running the same tire I am. Few years back I had a much quicker car( 70 Duster) and I ran the Hoosier bias QTP tires. Hooked outstanding even with super stock springs on a 9 sec car.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3066493
08/09/22 11:03 AM
08/09/22 11:03 AM
RMCHRGR
Spahn Ranch
Thanks for the replies.
Seems like there's very little chance a 29" tire would fit without cutting the front lip of the wheel well. At my level it does not seem worth cutting the car for a 1" larger tire so I will stick with a 28" tire. As long as a 275/60-15 drag radial will fit a 28 x 10 x 15 bias should fit as well.
This is from several years ago but this is what it looks like with the 275/60-15 tire.
[Re: RMCHRGR]
#3066494
08/09/22 11:07 AM
08/09/22 11:07 AM
B3422W5
Portage,michigan
This is from several years ago but this is what it looks like with the 275/60-15 tire. Try the 11.5 by 28 Hoosier Qtp. Excellent bite, will fit just fine. It’s actually 28 by 10
[Re: RMCHRGR]
#3066498
08/09/22 11:18 AM
08/09/22 11:18 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
I don't have a Duster but did the same front lip mod topside referred to, on my Plymouth B body. I studied the way many of them were done. The end observation was, as long as the lip is maintained, it will look pretty close to stock...even if it is relocated forward a couple inches. When the lip is totally cut off as many race cars are, it isn't the appearance I was going for. Not everyone would agree/no problem. I might not need the clearance right now, but it opens up options for later. Good luck with whatever you decide to do, even if it is to leave it alone.
Rich H.
Esse Quam Videri
[Re: RMCHRGR]
#3066513
08/09/22 11:46 AM
08/09/22 11:46 AM
Posts: 608 TN
1DGEMAN
TN
This is a no brainer. Look at any NHRA Stock eliminator Duster. That tire will work better on a 10 inch wheel.
Real Men shift for themselves
[Re: RMCHRGR]
#3066526
08/09/22 12:45 PM
08/09/22 12:45 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
This is from several years ago but this is what it looks like with the 275/60-15 tire. One thing to remember is a radial tire doesn't grow. A Bias tire will grow. My 68 Barracuda doesn't rub with a 28" Radial but it rubs the front just a little bit with a bias tire when it grows. It doesn't even rub enough to mark the tire, just enough to polish the front of the opening.
68 Barracuda Formula S 340
