Re: Modman with Dominator
[Re: Hyper Henry]
#3065968
08/07/22 04:47 AM
08/07/22 04:47 AM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
No experience here, just the knowledge that nobody has bragged about how well thier motor runs with one. Consider the fact that there is no tuned length, and cylinder to cylinder distribution may be poor? Open plenum single four intakes make serious power, and then there is the tunnelram option. I hope you go with one of those. There has got to be somebody out there looking for a modman so they can put what they want on top of thier motor,. IMHO, go with an intake that will perform up to your expectations.
[Re: Hyper Henry]
#3065993
08/07/22 09:32 AM
08/07/22 09:32 AM
Posts: 31,037 Oregon
AndyF
Maybe a dumb question but I already have a Modman intake for a 400(500ci race only) motor I am getting built and was wondering if anyone has run a single dominator with good success? If one is good than is two better?? LOL . I do have two matching dominators sitting on the shelf looking to be used....:o) Thanks for any constructive feedback. If you really want to run a Modman intake then talk to Kenny at Indy and follow his advice. Personally I don't think it is a very good intake manifold for a Dominator. If I wanted to run a Dominator on a low deck I'd use a 400-3 intake. On a race engine a well prepped 400-3 intake will probably be 25 hp ahead of a ModMan.
[Re: AndyF]
#3066007
08/07/22 10:41 AM
08/07/22 10:41 AM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
I’ve this. Purchased some years ago from Andy F. Was within 4 hundredths on me 540 against an Indy single plane. Billet top and Max Wedge ports. 1050 ish Thumper carb. Haven’t been out with the new car yet.
[Re: actionange]
#3066022
08/07/22 11:36 AM
08/07/22 11:36 AM
AndyF
Yeah that was an experiment to see if a ModMan could be made to work okay. It cost a fortune to carve out of billet but it worked pretty well. The net result of all of that testing was that it is just cheaper and easier to use a good single plane intake. Glad you have that bad boy mounted up. It looks killer. You can always tell people it is an AR Engineering prototype. One off, custom part.
[Re: Hyper Henry]
#3066161
08/08/22 08:52 AM
08/08/22 08:52 AM
Posts: 4,049 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Maybe a dumb question but I already have a Modman intake for a 400(500ci race only) motor I am getting built and was wondering if anyone has run a single dominator with good success? If one is good than is two better?? LOL . I do have two matching dominators sitting on the shelf looking to be used....:o) Thanks for any constructive feedback. The intake REALLY needs the runners extended for any application other than supercharged. As has been said we've done a bunch of thinking about what to do. A lot of the thinking went into what can be done that is relatively easy to duplicate. But, after i got into the porting, I felt I have an even better understanding and it's morphed into something a little different. I think that it'll work better than a single 4 FOR HIS APPLICATION. To aid in distribution the plenum gets bigger than a single 4, and for this it'll like the pump shot that a Holley has. I'd have no problem and wanted to retrofit TWO 4150's onto this intake but for a number of reasons (at least for now) it'll get the AFB's. With that said, i still feel it'll be as good or better than a single 4...We'll see and we'll share. Brent Wheeler is running very fast with his ported Modman with minor easy-to- duplicate changes. This intake will be different than his however.
