Re: 4 speed woes
[Re: 8urvette]
#3065669
08/05/22 11:57 PM
08/05/22 11:57 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
You killed 3rd gear. Either the speed gear or cluster. Libery makes a 9310 gear set that might live longer if you refrain from operatibg the car in the manner stated above.
Spinning hard and dead hooking it on the upshift will do that. Much like rolling a mechanical diode in a 727.
What clutch is in the car and how much does it weigh? You need something that slips a bit on WOT engagement.
Re: 4 speed woes
[Re: Jeremiah]
#3065723
08/06/22 11:08 AM
08/06/22 11:08 AM
Posts: 781 wine country
8urvette
wine country
What about cryo treating the gear set?
The clutch is a twin disc setup. No slip. I was thinking about adding a clutch tamer to it. Or do I stop with this 4 speed and go to something a bit stronger?
Re: 4 speed woes
[Re: 8urvette]
#3065868
08/06/22 07:44 PM
08/06/22 07:44 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
The clutch is a twin disc setup. No slip. I was thinking about adding a clutch tamer to it. Or do I stop with this 4 speed and go to something a bit stronger? I broke some 833 18 spline stuff with a Mcleod Street Twin but my Richmond 5-speed held up OK but it has cryo treated gears when I had them face-plated at Liberty's. I'm running a street HEMI box now with dual friction clutch now with good results. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: 4 speed woes
[Re: 8urvette]
#3066043
08/07/22 01:29 PM
08/07/22 01:29 PM
Posts: 103 Washington
weedburner
Washington
i dont make that to the wheels... what about a slipper valve? This would alleivate the harshness of dumping the clutch. Ive looking into clutch tamer before but didnt see the benefit at the time. LOL, Now Im thinking if I went with something like the mechanical clutch master slipper it would be in ever gear and would STOP me from shocking the gears the way I did. If you shift using the clutch pedal, installing a ClutchTamer will definitely help keep your transmission alive. The most important thing a stick shift drag racer can do is to soften the clutch's engagement rate to compliment the engine's power. Not only does that keep the engine operating up where it can make the most of its power potential, doing so also softens the impact on the rest of the drivetrain. It's your basic win/win. The first unit I made 12+ years ago I called the "Hillbilly Clutch Slipper", basically a $12 hydraulic screen door closer I bought at the local hardware store. It worked pretty much the same as the units I currently make, but as you can imagine many originally thought the hillbilly slipper was a joke. Here's a link to info showing that original install- Hillbilly Clutch SlipperFast forward to today, there are now winning NHRA racers using basically the same setup to further soften launch engagement of top shelf adjustable clutches. Much shorter cylinders now, but they effectively do the same thing that the original hillbilly slipper did. It's become one of the most cost-effective things a stick shift drag racer can do. Here's a link to a page of mine about applying nitrous in a clutch car, but the top part of the page has a couple graphs that show how slowing clutch engagement rate can affect the peak impact seen by the transmission's input and driveshaft. Note that 3rd gear gets hit the hardest in this G101a example... https://grannys.tripod.com/clutchtuningnitrous.htmlGrant
Re: 4 speed woes
[Re: 8urvette]
#3066111
08/07/22 06:56 PM
08/07/22 06:56 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Looks like a stock 18 spline tranny with a wiped out cluster gear. Okay, I've been street racing and drag strip racing for many years. I've learned the hard way that 2 things have to slip. Either the clutch or the tires with a stick car. Your choice. Over the past 40 years, I have never broke a tranny or rear gear. My car is a street strip car that has dipped into the high tens. Most of the time it is in the very low 11's. This with close to a 2 ton car!!! My combo is very conservative.. 11' Dual friction, 18 spline slick shifted tranny, 4:56 gears with a 29" tall tire. My engine make over 580HP at the wheels. I don't know how you shift. I've never seen you or know you, with that, Granny shifting is very hard on the drive train. Power shifting will lengthen the life of drive line parts. It's pretty hard to power shift a stock tranny above 5000 rpm. Also, what type of gear oil are you using? All of this is my experience and opinion. Take it as you like. I'm just trying to help.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 4 speed woes
[Re: 68LAR]
#3066124
08/07/22 09:37 PM
08/07/22 09:37 PM
8urvette
wine country
well thanks for the input. I wouldn't say I was granny shifting when it broke. I just tapped the clutch to help it release and banged it into gear. well... where 3rd gear used to be. It shifted like butter even at 7k. after i replaced all the synchros and had the gears deburred and the cleaned up
I'm wondering..... if i rebuild this 4 speed do i replace all the gears in the trans and all the bearings? I just rebuilt it a few months ago, maybe 1000 miles on it since then.
I was using sta-lube gear oil for this type of trans.
My other option would be to sell all my stuff off- my 540, the headers, holley MPFI, whats left of the 4 speed, the shortened d60 and go in a totally different direction with the car. But i dont think anyone here likes the ideas of battery powered cars so I wont go into that.
Re: 4 speed woes
[Re: 8urvette]
#3066146
08/07/22 11:30 PM
08/07/22 11:30 PM
Jeremiah
Rogue River, OR
68lar and weedburner have the info you need to male this work. The a833 will be just fine if you can drive it like lar said. Unloading and loading the transmission/drivetrain during a WOT upshift will break any of them. T5, gf5r, g101a, jerico w/ever
I have been having awesome luck running Redline heavy shock proof in my a833. Much less metal at service intervals and the trans is much quieter than with MTL. I am going to experiment with medium weight shock proof this round.
Re: 4 speed woes
[Re: 8urvette]
#3066147
08/07/22 11:39 PM
08/07/22 11:39 PM
Jeremiah
Rogue River, OR
My other option would be to sell all my stuff off- my 540, the headers, holley MPFI, whats left of the 4 speed, the shortened d60 and go in a totally different direction with the car. But i dont think anyone here likes the ideas of battery powered cars so I wont go into that. Replace the cluster and have it face plated if you plan on WOT shifts. I started with new 9310 speed gears and a 8620 cluster and have yet to break any hard parts. I did break the inner race of the rear mainshaft bearing however I think that was due to an oversize journal on the aftermarket mainshaft. I would never go back to synchros in a hotrod after have a face plated box in a few cars.
